ErgoMounts Ergotron Neo-Flex stand - for LCD display - black
Quicklinx: 7BM9WS00 Mfr#: 33-329-085
Type: Stand
£141.88 ex VAT
£170.25 inc VAT
Upgrade your widescreen display with five-inch (12.7 cm) height adjustment, tilt, pan and portrait-to-landscape rotation for optimum viewing. Embedded with patented motion technology, this stand enables light-touch adjustments without any knobs or levers.
  • Versatile adjustments
    With lift, pan, rotation, and tilt capabilities, the Ergotron Neo-Flex stand offers flexibility. Adjust your LCD display to your preferred height, angle, and orientation for an optimized viewing experience. Whether for work or leisure, the stand's adjustability ensures your screen is always in the perfect position.
  • Comprehensive compatibility
    Designed to support LCD displays ranging from 20" to 32", the Ergotron Neo-Flex accommodates a wide variety of screen sizes. It includes a VESA adapter kit, ensuring compatibility with mounting interfaces of 100 x 100 mm, 200 x 100 mm, 200 x 200 mm, and 75 x 75 mm. This broad compatibility makes it a versatile choice for virtually any desktop setup.
  • Easy installation and management
    The stand comes complete with cable ties and a monitor bracket, facilitating a clean and organized workspace. Landscape and portrait orientation details offer additional customization, allowing users to easily switch between modes according to their needs. The package's inclusion of essential accessories simplifies the installation process, making it straightforward to secure and manage your display.
Stand - desktop
Tilt
30°
Pan
360°
Lift
12.7cm
Rotation
90°
Adjustments
Tilt, pan, lift, rotation
6.7 kg
Recommended Use
LCD display
Recommended Display Size
20"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
16.3 kg
Package Content
Cable ties, monitor bracket, VESA adapter kit
3-year warranty
6.7 kg
Package Content
AV Furniture
Stand
Recommended Use
LCD display
Placing / Mounting
Desktop
20"-32"
Tilt
30°
Pan
360°
Lift
12.7cm
Rotation
90°
Adjustments
Max Load Weight
16.3 kg
Min Load Weight
7.3 kg
Adjustable height, rotating
Details
Portrait orientation, landscape orientation
Dimensions & Weight Details
58.7 cm x 32.7 cm x 19 cm / 7.5 kg
Limited warranty - 3 years
Type: Stand
Brand: ErgoMounts
