ErgoMounts ergatron neo-flex lcd lift std
Quicklinx: 7C7CWS00 Mfr#: 33-330-085
Affordable, height-adjustable dual-monitor stand for maximum productivity and comfort. Save time by using multiple applications at once - eliminate toggling back and forth between documents and programs. Simultaneously lift LCD screens to proper height for unsurpassed ergonomic comfort.
Ergotron Neo-Flex Dual LCD Lift Stand stand - for 2 LCD displays - black
Stand
Recommended Use
2 LCD displays
Recommended Display Size
Up to 22"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
15.4 kg
3-year warranty
AV Furniture
Stand
Recommended Use
2 LCD displays
Up to 22"
Max Load Weight
15.4 kg
Adjustable height
Limited warranty - 3 years
