Epson XP-860 A4 Colour Wireless Inkjet 3 in 1
Quicklinx: BX5SWS00 Mfr#: C11CD95401
Superior results
The XP-860 uses Epson's Claria Photo HD ink, a six-colour inkset that is ideal for producing superior-quality, long-lasting photographs. It delivers smooth tonal gradations, natural blacks and rich, vibrant colours for high-quality photos.
Mobile printing
Epson Connect consists of Epson iPrint – for easy wireless printing from smartphones and tablets; Epson Creative Print – print photos directly from Facebook, and Epson Email print – print from anywhere in the world by emailing photos and documents directly to the printer. AirPrint and Google Cloud Print are also supported.
Wireless connectivity
Automatic Wi-Fi set-up4 makes it quick and simple to connect to a Wi-Fi network, or alternatively compatible devices can be connected via Wi-Fi Direct without having to connect to a wireless router. Printing is also possible from Wireless PictBridge-compatible cameras.
Versatile printing
In addition to dual paper trays, the rear speciality media feed enables printing onto thick card and photo paper for extra creativity. Printing onto suitable CDs and DVDs is also possible. Fast print speeds mean you can print photos in just 10 seconds5.
Easy to control
The XP-860 has a 10.9cm interactive LCD touchscreen, and printing directly from a memory card is easy. A motorised control panel and automatic-opening output tray make for hassle-free printing.
  • Superior results
  • Mobile printing
    Epson Connect consists of Epson iPrint– for easy wireless printing from smartphones and tablets; Epson Creative Print – print photos directly from Facebook, and Epson Email print – print from anywhere in the world by emailing photos and documents directly to the printer. AirPrint and Google Cloud Print are also supported.
  • Wireless connectivity
    Automatic Wi-Fi set-up makes it quick and simple to connect to a Wi-Fi network, or alternatively compatible devices can be connected via Wi-Fi Direct without having to connect to a wireless router. Printing is also possible from Wireless PictBridge-compatible cameras.
  • Versatile printing
    In addition to dual paper trays, the rear speciality media feed enables printing onto thick card and photo paper for extra creativity. Printing onto suitable CDs and DVDs is also possible. Fast print speeds mean you can print photos in just 10 seconds.
  • Easy to control
Epson Expression Photo XP-860 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 6-ink
Max Printing Speed
Up to 9.5 ppm (mono) / up to 9 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 200 x 200 dpi
Scanning
4800 x 4800 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to Cloud
AC 230 V (50/60Hz)
39 cm x 33.9 cm x 19.1 cm
8.3 kg
Microsoft Certification
Compatible with Windows 7
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Features
Touch screen
AirPrint Enabled
Supported Flash Memory
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Copying
Automatic Duplexing
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (per cartridge)
Max Printing Speed
Ink Cartridge Configuration
6 cartridges (1 each: light cyan, light magenta, yellow, black, magenta, cyan)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, light cyan, light magenta
6-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Epson Claria Photo HD Ink
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
4800 x 4800 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Speed Dialing
60 station(s)
Automatic redialing
Document & Media Handling
Max Original Size
Original Type
Sheets
30 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
90 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets - Legal (216 x 356 mm) , ADF - 30 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 95 g/m²
Speed Details
Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 9.5 ppm - B/W (ISO/IEC 24734) , Printing: up to 9 ppm - colour (ISO/IEC 24734) , Printing: 10 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.6.8 or later, Windows 8
Software Included
Drivers & Utilities, EPSON Print CD, Epson Easy Photo Print, Epson Fax Utility
AC 230 V (50/60Hz)
21 Watt
Power Consumption Standby
6.9 Watt
Power Consumption Sleep
1.6 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (light magenta)
CISPR 22 Class B, FCC Part 15 B, UL 60950-1, CAN/CSA-C22.2 No. 60950-1
39 cm
33.9 cm
19.1 cm
8.3 kg
BX5S Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £14.99
BX5S Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.37
BX5S Epson A4 Iron On Transfer Pack 10sht In Stock £13.27
BX5S Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.37
BX5S Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £14.69
