Superior results
The XP-860 uses Epson's Claria Photo HD ink, a six-colour inkset that is ideal for producing superior-quality, long-lasting photographs. It delivers smooth tonal gradations, natural blacks and rich, vibrant colours for high-quality photos.
Mobile printing
Epson Connect consists of Epson iPrint – for easy wireless printing from smartphones and tablets; Epson Creative Print – print photos directly from Facebook, and Epson Email print – print from anywhere in the world by emailing photos and documents directly to the printer. AirPrint and Google Cloud Print are also supported.
Wireless connectivity
Automatic Wi-Fi set-up4 makes it quick and simple to connect to a Wi-Fi network, or alternatively compatible devices can be connected via Wi-Fi Direct without having to connect to a wireless router. Printing is also possible from Wireless PictBridge-compatible cameras.
Versatile printing
In addition to dual paper trays, the rear speciality media feed enables printing onto thick card and photo paper for extra creativity. Printing onto suitable CDs and DVDs is also possible. Fast print speeds mean you can print photos in just 10 seconds5.
Easy to control
The XP-860 has a 10.9cm interactive LCD touchscreen, and printing directly from a memory card is easy. A motorised control panel and automatic-opening output tray make for hassle-free printing.
Superior results
The XP-860 uses Epson's Claria Photo HD ink, a six-colour inkset that is ideal for producing superior-quality, long-lasting photographs. It delivers smooth tonal gradations, natural blacks and rich, vibrant colours for high-quality photos. -
Mobile printing
Epson Connect consists of Epson iPrint– for easy wireless printing from smartphones and tablets; Epson Creative Print – print photos directly from Facebook, and Epson Email print – print from anywhere in the world by emailing photos and documents directly to the printer. AirPrint and Google Cloud Print are also supported. -
Automatic Wi-Fi set-up makes it quick and simple to connect to a Wi-Fi network, or alternatively compatible devices can be connected via Wi-Fi Direct without having to connect to a wireless router. Printing is also possible from Wireless PictBridge-compatible cameras. -
Versatile printing
In addition to dual paper trays, the rear speciality media feed enables printing onto thick card and photo paper for extra creativity. Printing onto suitable CDs and DVDs is also possible. Fast print speeds mean you can print photos in just 10 seconds. -
Easy to control
- Epson Expression Photo XP-860 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 6-ink
- Max Printing Speed
- Up to 9.5 ppm (mono) / up to 9 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 200 x 200 dpi
- Scanning
- 4800 x 4800 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to Cloud
- Power
- AC 230 V (50/60Hz)
- 39 cm x 33.9 cm x 19.1 cm
- 8.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Copying
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (per cartridge)
- Ink Cartridge Configuration
- 6 cartridges (1 each: light cyan, light magenta, yellow, black, magenta, cyan)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, light cyan, light magenta
- 6-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Epson Claria Photo HD Ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 4800 x 4800 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 180 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 60 station(s)
- Automatic redialing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 90 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Input tray - 100 sheets - Legal (216 x 356 mm) , ADF - 30 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 95 g/m²
- Speed Details
- Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 9.5 ppm - B/W (ISO/IEC 24734) , Printing: up to 9 ppm - colour (ISO/IEC 24734) , Printing: 10 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct
- Operating System Support
- MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.6.8 or later, Windows 8
- Software Included
- Drivers & Utilities, EPSON Print CD, Epson Easy Photo Print, Epson Fax Utility
- Voltage Required
- 21 Watt
- Power Consumption Standby
- 6.9 Watt
- Power Consumption Sleep
- 1.6 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (light magenta)
- CISPR 22 Class B, FCC Part 15 B, UL 60950-1, CAN/CSA-C22.2 No. 60950-1
- 39 cm
- 33.9 cm
- 19.1 cm
- 8.3 kg
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.99 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £13.27 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
