Epson Workforce WF-7620DTWF
Quicklinx: C4V3WS00 Mfr#: C11CC97302
This business printer comes with a 35-sheet automatic document feeder and offers A3 duplex print, scan, copy and fax. As well as the two front loading paper trays, the rear specialty paper path means you can print on a wide range of thicker paper, envelopes or labels to suit your business needs.
  • A3 duplex 4-in-1
  • Mobile printing
    Epson connect allows you to print important office documents from smartphones and tablets. You can also print from anywhere in the world by emailing files directly to the printer, and store scanned documents in cloud services. In addition, this printer is also Google Cloud Print and Apple AirPrint compatible. For added versatility, Wi-Fi Direct allows easy printing from wireless devices without having to connect to a wireless router.
  • Printhead technology
    PrecisionCore, Epson's most advanced printhead technology, powers the industry-leading output quality and durability that Epson is renowned for, at the high speeds required for office, commercial and industrial printing.
  • Durable ink
    Epson's DURABrite ultra ink is ideal for producing laser-like business documents. Documents are water, smudge and highlighter resistant, while it's quick-drying properties make it perfect for duplex printing. The high-capacity, individual ink cartridges offer great savings, with a 50% lower cost-per-page than competitive lasers.
Epson WorkForce WF-7620DTWF - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
20000 pages
Max Printing Speed
Up to 18 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
A3 (297 x 420 mm) (max)
Media Type
Envelopes, plain paper, thick paper
Standard Media Capacity
500 sheets
Max Media Capacity
500 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
125 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Scan to Cloud
AC 230 V
56.7 cm x 48.6 cm x 41.8 cm
21.7 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
20000 pages
Display Features
Touch screen
AirPrint Enabled
Scan to Cloud
Supported Flash Memory
SD Memory Card, USB flash drive, SDHC Memory Card, SDXC Memory Card
Printing
Nozzle Configuration
800 nozzles (black), 3 x 256 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2.8 pl
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Automatic redialing, colour faxing
Document & Media Handling
Original Type
Sheets
35 sheets
Max Media Size
A3
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
500 sheets
Max Media Capacity
500 sheets
1 sheet
125 sheets
2 x input tray - 250 sheets - A3 (297 x 420 mm) , Bypass tray - 1 sheet , ADF - 35 sheets
Speed Details
Printing: up to 18 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734) , Printing: up to 8.7 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 6 ppm (A4) - colour duplex (ISO/IEC 24734)
1 x USB 2.0 , 1 x LAN , 1 x USB host
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, MS Windows Server 2003 R2, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later, Apple Mac OS X 10.5.9
Software Included
Drivers & Utilities
AC 230 V
19 Watt
Power Consumption Standby
8.5 Watt
Power Consumption Sleep
1.7 Watt
Consumables Included
1 x ink cartridge (black) ¦ 1 x ink cartridge (cyan) ¦ 1 x ink cartridge (magenta) ¦ 1 x ink cartridge (yellow)
ENERGY STAR Certified
56.7 cm
48.6 cm
41.8 cm
21.7 kg
C4V3 Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.53
C4V3 Epson A4 Iron On Transfer Pack 10sht In Stock £14.61
C4V3 Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.90
C4V3 Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.38
C4V3 Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £20.89
C4V3 Epson A3 Matte Paper Heavyweight 50 sheets In Stock £28.50
