Epson WORKFORCE WF-7525 PRTR
Quicklinx: 81RQWS00 Mfr#: C11CB58301
Time-saving features: Prints are delivered quickly and efficiently at up to 34 pages per minute in draft mode, and up to 15 mono and 8.4 colour pages per minute for business-quality documents.
Further boost speed with super-fast A4 double-sided printing at up to 7.7 mono and 5.2 colour pages per minute, while cutting paper usage and costs by up to 50 percent.
Productive: High-capacity 250-sheet paper tray for less frequent refilling and a 30-sheet Automatic Document Feeder for multiple page scanning, copying and faxing at up to A3.
Economical: See savings of up to 50 percent on cost per page compared to competitive lasers. Businesses can also print up to 1,000 pages, equivalent to two reams of paper, with Epson's individual XL Stag inks. ENERGY STAR-qualified reduced power consumption further cuts costs and environmental impact. Up to 80% lower energy consumption than competitive colour lasers and more affordable than the laser equivalent.
Get connected: Share across the entire business with Ethernet or Wi-Fi connectivity with enhanced WPA2 wireless security. The WF-7525 also comes with Epson Connect which offers even more flexibility and freedom, allowing users to quickly and easily print images and documents wirelessly from smartphones and tablet PCs. Additionally, users can print from anywhere in the world by emailing documents and images directly to the printer. Google Cloud Print is also supported.
Furthermore, the WF-7525 is AirPrint Ready which enables users to print emails, photos, web pages and documents directly from an iPad, iPhone and iPod Touch.
Easy to use: A 6.3cm colour LCD screen with accompanying PictBridge, USB flash and memory card slots offer straightforward PC-free printing.
  • True A3+ all-in-one
    A3+ prints with A3 fax, copy, scan.
  • Double-sided A4 prints
    Reduce paper usage by up to 50%
  • Productive
    500 sheet paper capacity.
  • Flexible
    30-sheet A4 duplex ADF.
  • Share securely
    Ethernet and WiFi connectivity.
  • Epson Connect
    Print from smartphones and tablet PCs. Email documents to the printer.
  • Google Cloud Print
    Print on the go from your smartphone or computer.
  • Apple Airprint
    Print directly from your iOS device.
Epson WorkForce WF-7525 - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 15 ppm (mono) / up to 8.2 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 1200 dpi
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
A3 plus (311 x 457 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
500 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AC 230 V
55.9 cm x 41.8 cm x 36.5 cm
18.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Broadcast Transmission
Yes (black only)
Colour faxing, group dialling, delayed sending
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
30 sheets
Max Media Size
A3
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
500 sheets
2 x input tray - 250 sheets , ADF - 30 sheets
Speed Details
Printing: up to 34 ppm (A4) - B/W , Printing: up to 34 ppm (A4) - colour , Printing: up to 15 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 8.2 ppm (A4) - colour (ISO/IEC 24734)
1 x USB 2.0 , 1 x USB host , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK, WPA2, TKIP, AES
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later, MS Windows Server 2008, MS Windows Server 2008 R2
Software Included
Epson Event Manager, Epson Easy Photo Print, Epson Fax Utility, Presto! PageManager 9
AC 230 V
20 Watt
Power Consumption Sleep
4.4 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year
55.9 cm
41.8 cm
36.5 cm
18.9 kg
81RQ Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.93
81RQ Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.93
