Epson WorkForce WF-7210DTW Colour Ink-Jet Printer
Quicklinx: F36MWS00 Mfr#: C11CG38401
Professional A3 printing
This A3 printer will meet the needs of even the most demanding home office and small office users. It can handle double-sided printing up to A3 and features two paper trays, which are ideal for alternating between different media. Furthermore, its PrecisionCore printhead produces high-quality, laser-like prints.
Enhance your productivity
This efficient, reliable and fast model offers A3 double-sided printing and print speeds of 18ppm in black and 10ppm in colour . It's simple to operate directly thanks to its easy-to-use 5.6cm LCD screen.
Minimise your outgoings
Dramatically reduce your costs; this printer offers up to 50 percent lower cost-per-page than competitors' laser models . Its inks are very economical; they're supplied individually, so you only replace the colour used. Giving great value for money, cartridges are available in standard, XL and XXL, with the highest yield delivering up to 2,200 pages .
Flexible wireless solutions
Print from anywhere in the office with Wi-Fi connectivity or use Wi-Fi Direct to print from compatible wireless devices without a Wi-Fi network. You can also print via NFC with a simple tap of a compatible Android device on the printer4. Epson's free mobile printing apps and solutions provide further versatility; Email Print allows you to send items to print from almost anywhere in the world5.
  • A3 printer with two trays
    Take advantage of this high quality, cost-effective A3 inkjet, with dual paper trays, double-sided printing and wireless connectivity options.
Epson WorkForce WF-7210DTW - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
15.58 kg
Inkjet Technology
Epson PrecisionCore
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A3
Max Media Size
A3 Plus (329 x 483 mm)
Print Speed
Up to 18 ppm - B/W (ISO/IEC 24734) , Up to 10 ppm - colour (ISO/IEC 24734) , Up to 32 ppm - B/W , Up to 20 ppm - colour
Max Resolution (B&W)
4800 x 2400 dpi
Max Resolution (Colour)
4800 x 2400 dpi
Max Resolution Class (B&W)
4800 x 2400 dpi
Max Resolution Class (Colour)
4800 x 2400 dpi
Automatic Duplexing
USB, LAN, Wi-Fi
AirPrint Enabled
Media Type
Envelopes, plain paper
Total Media Capacity
500 sheets
Monthly Duty Cycle (max)
20000 pages
Print server
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8, Microsoft Windows Server 2012 x64 Edition, Windows 10
1-year warranty
56.7 cm x 42.4 cm x 30.4 cm
Printer Type
Printer
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (black), 3 x 256 nozzles (cyan, magenta, yellow)
Minimum Ink Droplet Size
2.8 pl
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Type
Epson DURABrite Ultra inks
Print Speed
Wireless
USB, LAN, Wi-Fi
AirPrint Enabled
4800 x 2400 dpi
4800 x 2400 dpi
4800 x 2400 dpi
4800 x 2400 dpi
Automatic Duplexing
Media Handling
Media Type
Media Size Class
A3
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, A3 Plus (329 x 483 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
Media Weight
64 g/m² - 256 g/m²
500 sheets
Media Feeders
Input tray: 2 x automatic - 250 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
125 sheets
Duty Cycle
20000 pages
Print server
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Power supply - internal
22 Watt
Power Consumption Stand by
5.8 Watt
Power Consumption Sleep
1.5 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - carry-in
56.7 cm
42.4 cm
30.4 cm
15.58 kg
