A3 duplex printing
This A3 business printer offers A3 duplex printing for more convenient office printing. As well as the front loading paper trays, the rear speciality paper path means you can print on a wide range of thicker paper, envelopes or labels to suit your business needs.
Mobile printing
Epson Connect allows you to print important office documents from smartphones and tablets. You can also print from anywhere in the world by emailing files directly to the printer. In addition, this printer is also Google Cloud Print and Apple AirPrint compatible. For added versatility, Wi-Fi Direct allows easy printing from wireless devices without having to connect to a wireless router.
New printhead
PrecisionCore, Epson's most advanced printhead technology, powers the industry-leading output quality and durability that Epson is renowned for, at the high speeds required for office, commercial and industrial printing.
Durable ink
Epson's DURABrite Ultra Ink is ideal for producing laser-like business documents. Documents are water, smudge and highlighter resistant, while its quick-drying properties make it perfect for duplex printing. Available in 27XXL, 27XL and standard sizes, these high-capacity, individual ink cartridges offer great savings, with a 50% lower cost-per-page than competitive lasers4.
A3 business printer
Duplex A3 business printer that can quickly produce affordable business-quality documents.
- Epson WorkForce WF-7110DTW - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A3
- Max Media Size
- A3 Plus (329 x 483 mm)
- Print Speed
- Up to 18 ppm - B/W (ISO/IEC 24734) , Up to 10 ppm - colour (ISO/IEC 24734)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution (Colour)
- 600 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- Media Type
- Envelopes, labels, plain paper, thick paper
- Total Media Capacity
- 500 sheets
- Networking
- Print server
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Apple MacOS X 10.6 or later, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.5.9 or later, Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition
- 1-year warranty
- Printer Type
Printer
- Minimum Ink Droplet Size
- 2.8 pl
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Type
- Epson DURABrite Ultra inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 600 x 600 dpi
- 600 x 600 dpi
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, A3 Plus (329 x 483 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 500 sheets
- Media Feeders
- 2 x automatic - 250 sheets
- Max Media Capacity
- 500 sheets
- Networking
- Print server
- WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- Power Device
- Power supply - internal
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 1 year - on-site
- Width (Shipping)
- 72.6 cm
- Depth (Shipping)
- 56.3 cm
- Height (Shipping)
- 41.6 cm
- Weight (Shipping)
- 18.5 kg
Ink (5)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.99 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £13.27 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
Other bundles (1)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
