Engineered for business: Print high-quality colour documents at up to A3+ size as well as double-sided A4 documents.
High-speed: Prints are delivered quickly and efficiently with speeds of up to 34 pages per minute in draft mode, and up to 15 mono and 8.2 colour pages per minute for business-quality documents.
Productive: It has twin high-capacity 250-sheet paper trays for less frequent refilling. This also means you can keep it stocked with both A3 and A4 paper which helps save time and gives you media flexibility.
Share securely: Ethernet and Wi-Fi connectivity come as standard, featuring enhanced wireless security with WPA2 encryption.
Economical: See savings of up to 50 percent on cost per page compared to competitive lasers. Print up to 1,000 pages, equivalent to two reams of paper, with Epson's individual XL Stag inks, while double-sided printing can save paper usage and costs by up to 50 percent. ENERGY STAR-qualified reduced power consumption further cuts costs and environmental impact. Up to 80% lower energy consumption than competitive colour lasers.
Print high-quality color documents at up to A3+ size as well as double-sided A4 documents. -
High-speed
Prints are delivered quickly and efficiently with speeds of up to 34 pages per minute in draft mode, and up to 15 mono and 8.2 color pages per minute for business-quality documents. -
Productive
It has twin high-capacity 250-sheet paper trays for less frequent refilling. This also means you can keep it stocked with both A3 and A4 paper which helps save time and gives you media flexibility. -
Share securely
Ethernet and Wi-Fi connectivity come as standard, featuring enhanced wireless security with WPA2 encryption. -
Economical
See savings of up to 50 percent on cost per page compared to competitive lasers. Print up to 1,000 pages, equivalent to two reams of paper, with Epson’s individual XL Stag inks, while double-sided printing can save paper usage and costs by up to 50 percent. ENERGY STAR-qualified reduced power consumption further cuts costs and environmental impact. Up to 80% lower energy consumption than competitive color lasers.
- Epson WorkForce WF-7015 - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 12.3 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- Legal
- Max Media Size
- Legal (216 x 356 mm), A3 plus (329 x 423 mm)
- Print Speed
- Up to 34 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm) , Up to 15 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 8.2 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 5760 x 1440 dpi
- Max Resolution (Colour)
- 5760 x 1440 dpi
- Automatic Duplexing
- Interface
- USB, LAN, Wi-Fi(n)
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 500 sheets
- Media Handling
- 2x 250-sheet input trays
- Networking
- Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.4.11 or later
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 55.8 cm x 41.4 cm x 26.4 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
- Minimum Ink Droplet Size
- 2 pl
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Type
- Epson DURABrite Ultra inks
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 5760 x 1440 dpi
- 5760 x 1440 dpi
- Media Handling
Media Handling
- Media Type
- Media Size Class
- Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 500 sheets
- Media Feeders
- 2 x automatic - 250 sheets
- Networking
- Print server
- Data Link Protocol
- WEP, WPA-PSK, WPA2
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Power Device
- Power supply - internal
- 20 Watt
- Power Consumption Stand by / Sleep
- 3.7 Watt
- Software Included
- EPSON Easy Photo Print
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 55.8 cm
- 41.4 cm
- 26.4 cm
- 12.3 kg
