Epson WorkForce WF-2750DWF A4 Colour Inkjet Printer
Quicklinx: CJS5WS00 Mfr#: C11CF76401
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
£79.22 ex VAT
£95.06 inc VAT
Small business and home office users should look no further than this compact 4-in-1. The WF-2750DWF boasts double-sided, business-quality printing and individual inks for cost savings. It also features Wi-Fi and Wi-Fi Direct® and is compitable with Epson Connect1 to ensure quick and easy mobile printing.
Business quality
This 4-in-1 printer uses a PrecisionCore printhead to ensure top quality, laser-like performance. Fast print speeds and a 30-page automatic document feeder for multi-page, 1200dpi scanning, copying and faxing offer the ultimate in convenience. Wi-Fi and Wi-Fi Direct connectivity ensure the flexibility every small business needs.
Low running costs
The WF-2750DWF uses Epson's 16 series Pen and Crossword inks, available in a choice of standard or XL cartridges sizes to suit your specific printing needs. XL inks can help you to reduce your printing costs by up to 25% . The use of individual ink cartridges means only the colour used will need to be replaced, further reducing costs.
Mobile printing
Epson Connect compatibility offers useful features like scan-to-cloud, email print and the Epson iPrint app . The WF-2750DWF is also compatible with Apple AirPrint and Google Cloud print, letting you print seamlessly from smartphones and tablets.
Easy to use
Automatic Wi-Fi set-up4 helps make connection a breeze, while the 150-sheet front-loading paper cassette makes refilling easy. A 5.6cm LCD screen and a user-friendly menu makes navigating the WF-2750DWF simple and quick.
  • 4-in-1 colour inkjet
    Business-quality printing from this compact and affordable 4-in-1 with Wi-Fi, Wi-Fi Direct and double-sided printing.
Epson WorkForce WF-2750DWF - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
3000 pages
Max Printing Speed
Up to 33 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Standard Media Capacity
150 sheets
Output Trays Capacity
30 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to Cloud
AC 120/230 V (50/60Hz)
42.5 cm x 36 cm x 23 cm
6.6 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
3000 pages
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Scan to Cloud
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
400 nozzles (black), 128 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3.3 pl
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Document & Media Handling
Original Type
Sheets
30 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
95 g/m²
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm)
150 sheets
30 sheets
Input tray - 150 sheets , ADF - 30 sheets , Output tray - 30 sheets
Speed Details
Printing: up to 13 ppm - B/W (ISO/IEC 24734) , Printing: up to 7.3 ppm - color (ISO/IEC 24734) , Printing: up to 33 ppm - B/W , Printing: up to 20 ppm - colour , Printing: up to 6.5 ppm (A4) - B/W duplex , Printing: up to 4.5 ppm (A4) - colour duplex , Scanning: up to 3 ipm , Scanning: up to 3 ipm
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
Wi-Fi Direct
Operating System Support
MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows XP SP3, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 10
Software Included
Epson Event Manager, EPSON Scan, Epson Easy Photo Print, Epson Fax Utility, Presto! PageManager 9, EpsonNet Config
14 Watt
Power Consumption Standby
4.2 Watt
Power Consumption Sleep
1.3 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
ENERGY STAR Certified
42.5 cm
36 cm
23 cm
6.6 kg
CJS5 Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £13.48
CJS5 Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £9.81
CJS5 Epson Matte Paper Heavyweight A4 50 sheets In Stock £9.81
CJS5 Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £12.26
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Ink-jet
Max Print Speed: 30ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Epson
Price Range Ex VAT: 50 - 100
