Portable printing
The world's smallest and lightest wireless A4 inkjet printer , the WF-100W has a built-in battery that can be recharged anywhere via USB. It's small and compact, measuring just 309x154x61mm and weighing 1.6kg. Its wireless connectivity means the WF-100W cuts out all cables, allowing it to be used hassle-free both in clients' homes or in a vehicle.
Convenient
Compatible with Apple AirPrint and Google Cloud Print for wireless printing, the WF-100W also benefits from Epson Connect. As well as the Epson iPrint app for wireless printing from most tablets or smartphones, Epson Connect also includes Email Print, which means you can print from anywhere in the world .
High quality
The quality of this printer is reflected in the quality of the printouts. In fact, it is the only portable printer that uses pigment inks, for durable, smudge-free results.
Efficient
The WF-100W delivers an ISO print speed of 7ppm in black and 4ppm in colour4 and has an ink yield of up to 250 pages in black and 200 in colour5. The only portable printer with an LCD screen , it's always easy to set-up a Wi-Fi connection without the need for a PC, and to check ink supply levels.
Portable printing
Epson's smallest and lightest wireless A4 inkjet printer, the WF-100W has a built-in battery that can be recharged anywhere via USB. It's small and compact, measuring just 309x154x61mm and weighing 1.6kg. Its wireless connectivity means the WF-100W cuts out all cables, allowing it to be used hassle-free both in clients' homes or in a vehicle. -
Convenient
Compatible with Apple AirPrint and Google Cloud Print for wireless printing, the WF-100W also benefits from Epson Connect. As well as the Epson iPrint app for wireless printing from most tablets or smartphones, Epson Connect also includes Email Print, which means you can print from anywhere in the world. -
High quality
The quality of this printer is reflected in the quality of the printouts. In fact, it is the only portable printer that uses pigment inks for all colours for durable, smudge-free results. -
Efficient
The WF-100W delivers an ISO print speed of 7ppm in black and 4ppm in colour and has an ink yield of up to 250 pages in black and 200 in colour. With a 3.7cm LCD screen, it's always easy to set-up a Wi-Fi connection without the need for a PC, and to check ink supply levels.
- Epson WorkForce WF-100W - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 1.6 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 14 ppm - B/W , Up to 11 ppm - colour , Up to 7 ppm - B/W (ISO/IEC 24734) , Up to 4 ppm - colour (ISO/IEC 24734)
- Max Resolution (B&W)
- 5760 x 1440 dpi
- Max Resolution (Colour)
- 5760 x 1440 dpi
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Media Type
- Envelopes, plain paper
- Networking
- Print server
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x
- Enclosure Colour
- Black
- 30.9 cm x 15.4 cm x 6.1 cm
- Printer Type
- Enclosure Colour
- Black
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
- Minimum Ink Droplet Size
- 3 pl
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- 5760 x 1440 dpi
- 5760 x 1440 dpi
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- Media Weight
- 300 g/m²
- Media Feeders
- 1 x automatic - 20 sheets - Legal (216 x 356 mm)
- Networking
- Print server
- Remote Management Protocol
- IPP
- Connections
- 1 x USB 2.0 - 4 pin mini-USB Type B
- Included Accessories
- 2 x maintenance boxes
- Cables Included
- 1 x mini-USB cable
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- 11 Watt
- Power Consumption Stand by
- 4 Watt
- Power Consumption Sleep
- 1.3 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Operating)
- 45 dBA
- 30.9 cm
- 15.4 cm
- 6.1 cm
- 1.6 kg
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.99 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
