Epson WorkForce Pro WF-C8610DWF Colour Inkjet 35ppm Multifunction Printer
Quicklinx: DRFLWS00 Mfr#: C11CG69401BY
Functionality: Printer, Fax, Scanner, Copier
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
£837.95 ex VAT
£1,005.54 inc VAT
Save money
Designed for workgroups, your business can avoid the hidden employee productivity costs associated with centralised printing. Further lower costs by changing consumables less with its innovative ink supply system, helping to deliver a competitive TCO. Its low energy usage can reduce energy bills, and its simple but effective inkjet mechanism requires fewer replacement parts.
High productivity and low intervention
Don't wait for prints with no warm up time and a fast First Page Out Time (FPOT) of 5.5 seconds. Produce up to 5,800 pages in monochrome and 4,600 in colour without changing supplies with large ink cartridges . Print on a wide range of media including recycled paper, glossy media, envelopes and labels.
Reduce your impact
Benefit from low-power consumption due to the no-heat technology of inkjet printing, along with no ozone emissions. Also, fewer additional parts are needed, such as fusers, drums, developers etc, unlike a laser.
Built for business
A range of software and tools provide secure print options, efficient scanning and help manage devices remotely. NFC and wireless connectivity also supports printing from mobile devices. And with its smartphone inspired user interface and touchscreen, it's intuitive to operate.
  • A3 business inkjet MFD
    This highly reliable A3 business inkjet MFD, keeps costs low and productivity high, with a fast FPOT for small to medium workgroups.
Epson WorkForce Pro WF-C8610DWF - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
500 - 5000 pages
Max Copying Speed
Up to 22 ppm (mono) / up to 21 ppm (colour)
Max Copying Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Copying Resolution Class
Max Printing Speed
Up to 24 ppm (mono) / up to 24 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
55 x 127 mm (min) - 330 x 1200 mm (max)
Media Type
Envelopes, plain paper, recycled paper, glossy photo paper
Standard Media Capacity
335 sheets
Max Media Capacity
1835 sheets
Bypass Feeder Capacity
85 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
Gigabit LAN, NFC, USB 3.0, USB 2.0 host, Wi-Fi(ac)
Office Machine Features
Scan to e-mail, scan to network, scan to FTP, scan to SharePoint, scan to USB host
AC 230 V
61.3 cm x 75.5 cm x 49.3 cm
45.8 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
75000 pages
500 - 5000 pages
Display Colour Support
Display Features
Touch screen
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (black), 3 x 800 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
4.6 pl
Printer Drivers / Emulations
EPSON ESC/P-R
Ink Type
Epson DURABrite Pro inks
Automatic Duplexing
First Print Out Time B/W
5.5 sec
First Print Out Time Colour
5.5 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Scanning Resolution Details
1200 x 2400 dpi - flatbed , 600 x 600 dpi - ADF
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 550 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
2000 station(s)
Broadcast Transmission
Automatic redialing, delayed sending
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Supported Original Sizes
A4 (210 x 297 mm), A3 (297 x 420 mm)
Original Type
Sheets
50 sheets
Min Media Size
55 x 127 mm
Max Media Size
A3
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, SRA3 (320 x 450 mm), 200 x 250 mm, Tabloid (279 x 432 mm), A3 Plus (329 x 483 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International C4 (229 x 324 mm)
335 sheets
Max Media Capacity
1835 sheets
85 sheets
250 sheets
Input tray - 85 sheets , Input tray - 250 sheets , ADF - 50 sheets , Output tray - 250 sheets
Speed Details
Printing: up to 35 ppm - B/W , Printing: up to 35 ppm - colour , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 24 ppm - colour (ISO/IEC 24734) , Printing: up to 13 ppm (A3) - B/W (ISO/IEC 24734) , Printing: up to 13 ppm (A3) - colour (ISO/IEC 24734) , Printing: up to 16 spm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 16 spm (A4) - colour duplex (ISO/IEC 24734) , Printing: up to 11 spm (A3) - B/W duplex (ISO/IEC 24734) , Printing: up to 11 spm (A3) - colour duplex (ISO/IEC 24734) , Copying: up to 22 ipm - B/W (ISO/IEC 24735) , Copying: up to 21 ipm - colour (ISO/IEC 24735) , Scanning: up to 25 ipm (A4) - B/W (200 dpi) , Scanning: up to 25 ipm (A4) - colour (200 dpi) , Scanning: up to 45 ipm (A4) - B/W duplex (200 dpi) , Scanning: up to 45 ipm (A4) - colour duplex (200 dpi)
1 x USB 3.0 - 9 pin USB Type B , 3 x USB 2.0 host , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, SSL, WEP, WPA2, IPsec, 802.1x, WPA2-PSK, PING, Wi-Fi Direct
Operating System Support
Linux, MS Windows XP SP3, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2012 R2, Android 4.0 or later, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10, MS Windows Server 2016, MS Windows XP Professional x64 Edition SP2
AC 230 V
39 Watt
Power Consumption Standby
17 Watt
Power Consumption Sleep
1.3 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
ENERGY STAR Certified
Limited warranty - 1 year - on-site
61.3 cm
75.5 cm
49.3 cm
45.8 kg
Sound Emission
51 dBA (operating)
Functionality: Fax
Functionality: Scanner
Functionality: Copier
Output Type: Colour
Technology: Ink-jet
Max Print Speed: 35ppm
Max Paper Size: 330 x 1200 mm
Brand: Epson
Price Range Ex VAT: £750 - £1000
