Cut your environmental impact and business printing costs, all while increasing productivity with less intervention and enhanced security.
Fast, small workgroup MFD
- Epson WorkForce Pro WF-C5710DWF - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson PrecisionCore - 4-ink
- Monthly Duty Cycle (max)
- 45000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Max Copying Speed
- Up to 22 ppm (mono) / up to 22 ppm (colour)
- Max Copying Resolution
- Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Copying Resolution Class
- Max Printing Speed
- Up to 24 ppm (mono) / up to 24 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Printing Resolution Class
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 64 x 127 mm (min) - 216 x 60000 mm (max)
- Media Type
- Envelopes, plain paper, recycled paper, glossy photo paper
- Standard Media Capacity
- 330 sheets
- Max Media Capacity
- 830 sheets
- Bypass Feeder Capacity
- 80 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to FTP
- Power
- AC 120/230 V (50/60Hz)
- 42.5 cm x 53.5 cm x 35.7 cm
- 18.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 45000 pages
- 250 - 2500 pages
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- Inkjet Technology
- Nozzle Configuration
- 800 nozzles (black), 3 x 800 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3.8 pl
- Printer Drivers / Emulations
- EPSON ESC/P-R
- Ink Type
- Epson DURABrite Ultra inks
- First Print Out Time B/W
- 5 sec
- First Print Out Time Colour
- 6 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Scanning Resolution Details
- 1200 x 2400 dpi - flatbed , 1200 x 1200 dpi - ADF
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 550 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- Delayed Transmission
- E-mail function, colour faxing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 64 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, B6 (125 x 176 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International C4 (229 x 324 mm)
- 330 sheets
- 830 sheets
- 80 sheets
- 150 sheets
- Input tray - 80 sheets size: 64 x 127 mm - 216 x 60000 mm weight: 64 g/m² - 256 g/m² , Input tray - 250 sheets size: 89 x 127 mm - Legal (216 x 356 mm) weight: 64 g/m² - 160 g/m² , ADF - 50 sheets size: A5 (148 x 210 mm) - Legal (216 x 356 mm) weight: 64 g/m² - 160 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 34 ppm - B/W , Printing: up to 34 ppm - colour , Printing: up to 15 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 15 ppm (A4) - colour duplex (ISO/IEC 24734) , Copying: up to 22 ipm - B/W (ISO/IEC 24735) , Copying: up to 22 ipm - colour (ISO/IEC 24735) , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 24 ppm - colour (ISO/IEC 24734) , Scanning: up to 24 ipm (A4) - B/W , Scanning: up to 24 ipm (A4) - colour , Scanning: up to 8 ipm (A4) - B/W duplex , Scanning: up to 8 ipm (A4) - colour duplex
- 2 x USB host - 4 pin USB Type A , 1 x USB 2.0 , 1 x Gigabit LAN - RJ-45
- LDAP, SSL, Apple Bonjour, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, ARP, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows XP SP2 or later, MS Windows XP Professional x64 Edition, MS Windows XP SP3, MS Windows XP 64-bit Edition, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, MS Windows Server 2003 R2, MS Windows Server 2003 R2 x64 Edition, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8, Windows 8.1, MS Windows Server 2012 R2, MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 10, Apple Mac OS X 10.10.x, Apple Mac OS X 10.11.x, Apple Mac OS X 10.12.x
- Software Included
- Drivers & Utilities, Epson Document Capture Pro
- Voltage Required
- 23 Watt
- Power Consumption Standby
- 10 Watt
- Power Consumption Sleep
- 1.5 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- Limited warranty - 1 year - carry-in
- 42.5 cm
- 53.5 cm
- 35.7 cm
- 18.4 kg
- Sound Emission
- 54 dBA (operating)
Epson T9451 XL Size - Black Original Ink Cartridge | In Stock | £58.36 |
Epson T9441 Black Original Ink Cartridge | In Stock | £37.46 |
Epson T9454 XL Size - Yellow Original Ink Cartridge | In Stock | £77.94 |
Epson T9444 L Size - Yellow Original Ink Cartridge | In Stock | £43.48 |
Epson T9453 XL - Magenta Original Ink Cartridge | In Stock | £77.94 |
Epson T9443 L Size - Magenta Original Ink Cartridge | In Stock | £46.74 |
Epson T9452 XL - Cyan Original Ink Cartridge | In Stock | £74.06 |
Epson T9442 Cyan Original Ink Cartridge | In Stock | £43.48 |
Epson T9461 XXL Size - Black Original Ink Cartridge | In Stock | £120.80 |
