Epson WORKFORCE PRO WF-C5290DW
Quicklinx: DD15WS00 Mfr#: C11CG05401BY
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Marketing description is not available.
  • Fast, small workgroup printer
    Reduce your business printing costs and environmental impact, all while increasing productivity with less intervention and enhanced security.
Epson WorkForce Pro WF-C5290DW - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
15.3 kg
Inkjet Technology
Epson PrecisionCore
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
216 x 60000 mm
Min Media Size (Custom)
64 mm x 127 mm
Max Media Size (Custom)
216 mm x 60000 mm
Print Speed
Up to 34 ppm - B/W , Up to 34 ppm - colour , Up to 24 ppm - B/W (ISO/IEC 24734) , Up to 24 ppm - colour (ISO/IEC 24734) , Up to 15 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 15 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
4800 x 1200 dpi
Max Resolution (Colour)
4800 x 1200 dpi
Max Resolution Class (B&W)
4800 x 1200 dpi
Max Resolution Class (Colour)
4800 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Language Simulation
PCL 5C, PostScript 3, PCL 6, EPSON ESC/P Raster, PDF 1.7
Media Type
Envelopes, labels, plain paper, photo paper, recycled paper, postcards, glossy paper
Total Media Capacity
330 sheets
Media Handling
250-sheet input tray, 80-sheet multipurpose tray
Monthly Duty Cycle (max)
45000 pages
Recommended Monthly Volume
250 - 2500 pages
Print server
Linux, Microsoft Windows XP 64-bit Edition, Microsoft Windows XP SP2 or later, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X 10.7.x, Microsoft Windows Server 2003 R2 x64 Edition, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x, Apple MacOS X 10.11.x, Microsoft Windows Server 2016
1-year warranty
42.5 cm x 53.5 cm x 35.7 cm
Printer Type
Printer
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (black), 3 x 800 nozzles (cyan, magenta, yellow)
Minimum Ink Droplet Size
3.8 pl
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Type
Epson DURABrite Ultra inks
Print Speed
Built-in Devices
Touch screen
Wired
AirPrint Enabled
4800 x 1200 dpi
4800 x 1200 dpi
4800 x 1200 dpi
4800 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
5 sec
First Print Out Time Colour
6 sec
Language Simulation
Media Handling
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 x 60000 mm
64 mm x 127 mm
216 mm x 60000 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 89 x 127 mm
Envelope Sizes
International DL (110 x 220 mm), International C4 (229 x 324 mm)
Media Weight
64 g/m² - 256 g/m²
330 sheets
Media Feeders
Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 160 g/m² , Input tray: 1 x automatic - 80 sheets - 216 x 60000 mm weight: 64 g/m² - 256 g/m²
Max Media Capacity
830 sheets
Output Trays Capacity
150 sheets
Duty Cycle
45000 pages
250 - 2500 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS
Security Protocols & Features
SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, ARP, Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Power supply - internal
Frequency Required
50 - 60 Hz
22 Watt
Power Consumption Stand by
7 Watt
Power Consumption Sleep
1.2 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
Sound Emission (Operating)
55 dBA
42.5 cm
53.5 cm
35.7 cm
15.3 kg
DD15 Epson T9451 XL Size - Black Original Ink Cartridge In Stock £58.26
DD15 Epson T9441 Black Original Ink Cartridge In Stock £37.27
DD15 Epson T9454 XL Size - Yellow Original Ink Cartridge In Stock £78.22
DD15 Epson T9444 L Size - Yellow Original Ink Cartridge In Stock £43.48
DD15 Epson T9453 XL - Magenta Original Ink Cartridge In Stock £73.21
DD15 Epson T9443 L Size - Magenta Original Ink Cartridge In Stock £46.91
DD15 Epson T9452 XL - Cyan Original Ink Cartridge In Stock £73.38
DD15 Epson T9442 Cyan Original Ink Cartridge In Stock £43.48
DD15 Epson T9461 XXL Size - Black Original Ink Cartridge In Stock £121.21
