This small workgroup business printer is perfect for the business environment, from small offices to large corporates who may have traditionally used lasers and want to cut costs, increase productivity and reduce downtime. This is while also cutting their business' environmental impact and improving their CSR reputation.
Fast, small workgroup printer
Increase productivity with less intervention, all while cuting your environmental impact and business printing costs.
- Epson WorkForce Pro WF-C5210DW - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 15.3 kg
- Inkjet Technology
- Epson PrecisionCore
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- 216 x 60000 mm
- Min Media Size (Custom)
- 64 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 60000 mm
- Print Speed
- Up to 34 ppm - B/W , Up to 34 ppm - colour , Up to 24 ppm - B/W (ISO/IEC 24734) , Up to 24 ppm - colour (ISO/IEC 24734) , Up to 15 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 15 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 4800 x 1200 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Max Resolution Class (B&W)
- 4800 x 1200 dpi
- Max Resolution Class (Colour)
- 4800 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Language Simulation
- EPSON ESC/P Raster
- Media Type
- Envelopes, labels, plain paper, photo paper, recycled paper, postcards, glossy paper
- Total Media Capacity
- 330 sheets
- Media Handling
- 250-sheet input tray, 80-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 45000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows XP 64-bit Edition, Microsoft Windows XP SP2 or later, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X 10.7.x, Microsoft Windows Server 2003 R2 x64 Edition, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x, Apple MacOS X 10.11.x, Microsoft Windows Server 2016
- 1-year warranty
- 42.5 cm x 53.5 cm x 35.7 cm
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 800 nozzles (black), 3 x 800 nozzles (cyan, magenta, yellow)
- Minimum Ink Droplet Size
- 3.8 pl
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Type
- Epson DURABrite Ultra inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 4800 x 1200 dpi
- 4800 x 1200 dpi
- 4800 x 1200 dpi
- 4800 x 1200 dpi
- First Print Out Time B/W
- 5 sec
- First Print Out Time Colour
- 6 sec
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 216 x 60000 mm
- 64 mm x 127 mm
- 216 mm x 60000 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 89 x 127 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C4 (229 x 324 mm)
- Media Weight
- 64 g/m² - 256 g/m²
- 330 sheets
- Media Feeders
- Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 160 g/m² , Input tray: 1 x automatic - 80 sheets - 216 x 60000 mm weight: 64 g/m² - 256 g/m²
- Max Media Capacity
- 830 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 45000 pages
- 250 - 2500 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS
- SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, ARP, Wi-Fi Direct
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- Power Device
- Power supply - internal
- Frequency Required
- 50 - 60 Hz
- 21 Watt
- Power Consumption Stand by
- 7 Watt
- Power Consumption Sleep
- 1.2 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - carry-in
- Sound Emission (Operating)
- 55 dBA
- 42.5 cm
- 53.5 cm
- 35.7 cm
- 15.3 kg
