Epson Workforce Pro WF-5690DWF A4 Colour Inkjet Multifunction Printer
Quicklinx: 9DL5WS00 Mfr#: C11CD14301BY
Low running costs
The WorkForce Pro WF-5690DWF has an up to 50 percent lower cost per page than competitive colour lasers, saving you money as you take advantage of this printer's high capacity ink cartridges of up to 4,000 pages². And there are fewer parts to replace than a laser.
Ecological
The WF-5690DWF uses up to 80 percent less power than competitive colour lasersthanks, in part, to its no heat technology. No ozone gases are emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment.
Save time
This efficient multifunction business printer is faster than a laser on typical print jobs¹, with print speeds of up to 34ppm in mono and 30ppm in colour, or 20ppm ISO print speed in both³. Its high paper capacity of 580 sheets means less time is spent refilling, and it has a high monthly duty cycle of up to 35,000 pages4.
Built for business
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. Prints dry fast thanks to the DURABrite Ultra ink. Scan-to functions, LDAP support and PDL emulations help this printer easily integrate into the business environment. Its intuitive large colour touch-screen makes functions readily available, and the rear manual paper tray lets you print on a range of media.
  • Ecological and low-cost A4 multifunction
    This A4 multifunction printer seamlessly integrates into medium to large enterprises. Cut up to 50% of your printing costs and up to 80% of your energy use , while reducing user intervention and enhancing productivity.
  • Environmentally-friendly and low-cost A4 printing, scanning, copying and faxing
    Designed for businesses that have traditionally used lasers and want to cut costs, increase productivity and reduce downtime. Epson's clean technology helps create a more environmentally-friendly workplace, and PDL printer emulations and Gigabit Ethernet are ideal for enterprise integration.
  • Low running costs
    For cost-conscious offices this business multifunction has significant advantages over comparable colour laser printers. The high-yield ink cartridges help it to achieve an up to 50 percent lower cost per page than competitive colour laser printers . It uses Epson's DURABrite Ultra inks, in high-capacity ink cartridges of up to 4,000 pages , which ensure efficiency and productivity.
  • Ecological
    It uses up to 80 percent less power than competitive colour lasers thanks to its no-heat technology . No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment. And there are fewer consumables and parts to replace than a comparable laser.
  • Enhance productivity
    Focused on keeping offices productive, this multifunction is faster than competitive colour lasers on typical print jobs , as there is no warm up time needed. It delivers fast and efficient business printing, and is capable of print speeds of up to 34ppm in mono and 30ppm in colour, or 20ppm ISO print speeds in both . Automatic double-sided printing, scanning, copying and faxing make any job easy and efficient, perfect for the business environment. It has a high paper capacity of up to 580 sheets, including a second optional 250-sheet tray, meaning that less time is spent refilling.
  • Easy to use
    Easily control the main functions with its smartphone-like 10.9cm colour touch-screen. Automatic double-sided duplex printing as standard makes any job easy and means less paper is used too. Directly print from, or scan to, a USB memory stick. In addition, its front-loading ink cartridges are easy to change.
  • PrecisionCore
    PrecisionCore technology powers the output quality and reliability that Epson is known for, at the speeds required for office, commercial and industrial printing. Its use of PrecisionCore aids printing onto a range of different media and enables the rear paper feed tray to be used for printing onto thicker card, envelopes and labels. And it has a high monthly duty cycle of up to 35,000 pages4.
  • Built for business
    Its flexible connectivity allows this multifunction printer to seamlessly integrate into enterprise infrastructures. Wi-Fi and Wi-Fi Direct, PDL printer emulations, and Gigabit Ethernet all help to boost office productivity. PC-less scan-to functions, including Microsoft SharePoint using Document Capture Pro5, and scan-to-email with LDAP address book compatibility, make it ideal for sharing documents. Users can also securely print using a PIN code to release confidential documents.
  • Print from anywhere
    Stay connected and productive. Email Print for Enterprise allows you to securely send documents directly to the multifunction printer. Available with direct printing and pull print modes, this secure system integrates seamlessly into your existing IT infrastructure.
Epson WorkForce Pro WF-5690DWF - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
35000 pages
Max Printing Speed
Up to 20 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
330 sheets
Max Media Capacity
580 sheets
Bypass Feeder Capacity
80 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to folder, scan to Cloud
AC 230 V
46.1 cm x 44.2 cm x 34.2 cm
14.3 kg
Microsoft Certification
Compatible with Windows 7
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
35000 pages
Display Features
Touch screen
AirPrint Enabled
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2.8 pl
Printer Drivers / Emulations
PCL 5e, PCL 6, PCL 5c, PDF 1.7
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
7 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Automatic redialing, e-mail function, colour faxing
Document & Media Handling
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
330 sheets
Max Media Capacity
580 sheets
80 sheets
150 sheets
Input tray - 250 sheets , Bypass tray - 80 sheets , Output tray - 150 sheets , ADF - 35 sheets
Speed Details
Printing: up to 20 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - colour (ISO/IEC 24734) , Printing: up to 30 ppm - colour , Printing: up to 34 ppm - B/W , Printing: up to 11 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - colour (ISO/IEC 24734)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES
Operating System Support
MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits)
Software Included
Drivers & Utilities
AC 230 V
22 Watt
Power Consumption Standby
8.9 Watt
Power Consumption Sleep
2.6 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Limited warranty - 1 year - on-site
46.1 cm
44.2 cm
34.2 cm
14.3 kg
Sound Emission
52 dBA (operating)
9DL5 Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.37
9DL5 Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £14.69
