Low running costs
The WorkForce Pro WF-5110DW has an up to 50 percent lower cost per page than competitive colour lasers , saving you money as you take advantage of this printer's high capacity ink cartridges of up to 4,000 pages . And there are fewer parts to replace than a laser.
Ecological
The WF-5110DW uses up to 80 percent less power than competitive colour lasers thanks, in part, to its no heat technology. No ozone gases are emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment.
Save time
This efficient business printer is faster than a laser on typical print jobs , with print speeds of up to 34ppm in mono and 30ppm in colour, or 20ppm ISO print speed in both . Its high paper capacity of 580 sheets means less time is spent refilling, and a monthly duty cycle of up to 35,000 pages4means you can print lots in confidence.
Built for business
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. Prints dry fast thanks to the DURABrite Ultra ink. Print securely with Email Print for Enterprise. Epson Connect5 lets you easily print from smartphones, tablets and more, and its Wi-Fi Direct capability lets you print from supported wireless devices without connecting to a router.
Ecological and low-cost A4 printer
Small to medium offices can cut printing costs by up to 50% and energy use by up to 80% with this A4 printer, while enhancing productivity. -
Environmentally-friendly and low-cost A4 printing
A small workgroup printer, perfect for businesses that have traditionally used lasers and want to cut costs, increase productivity and reduce downtime, while also reducing their environmental impact. Epson's clean technology helps create a more environmentally-friendly workplace. -
Low running costs
For cost-conscious offices this business printer has significant advantages over comparable colour laser printers. The high-yield ink cartridges help the WF-5110DW to achieve an up to 50 percent lower cost per page than competitive colour laser printers . It uses Epson's DURABrite Ultra inks, in high-capacity ink cartridges of up to 4,000 pages , which ensure efficiency and productivity. -
Ecological
This printer uses up to 80 percent less power than competitive colour lasers thanks to its no-heat technology . No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment. And there are fewer consumables and parts to replace than a comparable laser. -
Enhance productivity
Focused on keeping offices productive, the WorkForce Pro WF-5110DW is faster than competitive colour lasers on typical print jobs , as there is no warm up time needed. It delivers fast and efficient business printing, and is capable of print speeds of up to 34ppm in mono and 30ppm in colour, or 20ppm ISO print speeds in both . It has a high paper capacity of up to 580 sheets, including a second optional 250-sheet tray, meaning that less time is spent refilling. -
Easy to use
The 5.6cm mono LCD mono screen allows for easy control of the main functions. Automatic double-sided duplex printing as standard makes any job easy and means less paper is used too. In addition, front-loading ink cartridges are easy to change. -
PrecisionCore
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. It's the WF-5110DW's use of PrecisionCore that aids high-speed printing and enables the rear feed to be used for printing on thicker card, envelopes and labels. And it has a high monthly duty cycle of up to 35,000 pages4. -
Built for business
Its flexible connectivity allows this printer to seamlessly integrate into office networks. Wi-Fi, Wi-Fi Direct and Gigabit Ethernet help help to boost office productivity. -
Print from anywhere
Stay connected and productive. Email Print for Enterprise5 allows you to securely send documents directly to the printer. Available with direct printing and pull print modes, this secure system integrates seamlessly into your existing IT infrastructure.
- Epson WorkForce Pro WF-5110DW - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 11.3 kg
- Inkjet Technology
- Epson PrecisionCore
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 34 ppm - B/W , Up to 30 ppm - colour , Up to 20 ppm - B/W (ISO/IEC 24734) , Up to 20 ppm - colour (ISO/IEC 24734) , Up to 11 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 11 ppm - colour duplex (ISO/IEC 24734) - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 4800 x 1200 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Language Simulation
- EPSON ESC/P Raster, Windows GDI driver
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 330 sheets
- Media Handling
- 250-sheet input tray, 80-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 35000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Apple MacOS X 10.6 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition
- 46.1 cm x 44.2 cm x 28.4 cm
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
- Minimum Ink Droplet Size
- 2.8 pl
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Type
- Epson DURABrite Ultra inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 4800 x 1200 dpi
- 4800 x 1200 dpi
- First Print Out Time B/W
- 7 sec
- First Print Out Time Colour
- 7 sec
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- Media Weight
- 64 g/m² - 256 g/m²
- 330 sheets
- Media Feeders
- 1 x automatic - 250 sheets , 1 x automatic - 80 sheets
- Max Media Capacity
- 580 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 35000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP, IPP, HTTP
- SSL, WEP, IPsec, 802.1x, TKIP, AES, Wi-Fi Direct
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- Power Device
- Power supply - internal
- 24 Watt
- Power Consumption Stand by
- 5.5 Watt
- Power Consumption Sleep
- 1.6 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Sound Emission (Operating)
- 51 dBA
- 46.1 cm
- 44.2 cm
- 28.4 cm
- 11.3 kg
Ink (11)
Epson T7891 XXL Black Print Cartridge | In Stock | £50.89 |
Epson T7892 XXL Cyan Ink Cartridge | In Stock | £53.20 |
Epson T7893 XXL Magenta Print Cartridge | In Stock | £57.96 |
Epson T7894 XXL Yellow Ink Cartridge | In Stock | £57.96 |
Epson 79XL Black Ink Cartridge | In Stock | £32.47 |
Epson 79XL Cyan Ink Cartridge | In Stock | £32.02 |
Epson 79XL Magenta Ink Cartridge | In Stock | £32.02 |
Epson 79 Black Ink Cartridge | In Stock | £19.73 |
Epson 79 Cyan Ink Cartridge | In Stock | £18.43 |
Epson 79 Magenta Ink Cartridge | In Stock | £18.43 |
Epson 79 Yellow Ink Cartridge | In Stock | £18.43 |
Other bundles (3)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.92 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.58 |
