Epson WorkForce Pro WF-4720DWF Colour Ink-Jet Multifunction Printer
Quicklinx: DKTMWS00 Mfr#: c11cf74401
Compact yet mighty
The compact yet feature rich WF-4720DWF is proof that great things can come in small packages. Its stylish design includes a 6.8cm touchscreen.
Business features that matter
Rely on the WF-4720DWF for top quality, laser-like prints thanks to Epson's most advanced printhead technology, PrecisionCore. Everyday tasks are easy with its 35 page automatic document feeder and 250 sheet paper tray. And share and organise documents with Scan-to: Email, Cloud, FTP and Network options
Speed up operations
Ensure your business runs smoothly with swift print speeds of 20ppm in both black and colour , and fast double-sided printing.
Low running costs
Achieve professional looking documents that are water, smudge and highlighter resistant, with Epson's DURABrite Ultra Ink. Offering great value, the inks are supplied individually, so you only ever have to replace the colour used. Plus, with XL cartridges you can print up to 2,600 black and 1,900 colour pages4.
Desk-free printing
Print from anywhere in the office with Wi-Fi connectivity or use Wi-Fi Direct to print from compatible wireless devices without a Wi-Fi network. You can also print via NFC with a simple tap of a compatible Android device on the printer . And there's Epson's free mobile printing apps and solutions including Email print, which allows you to send items to print from almost anywhere in the world .
  • Compact yet mighty
  • B{business features that matter
    }Rely on the WF-4720DWF for top quality, laser-like prints thanks to Epson's most advanced printhead technology, PrecisionCore. Everyday tasks are easy with its 35 page automatic document feeder and 250 sheet paper tray. And share and organise documents with Scan-to: Email, Cloud, FTP and Network options.
  • Speed up operations
    Ensure your business runs smoothly with swift print speeds of 20ppm in both black and colour.
  • Low running costs
    Achieve professional looking documents that are water, smudge and highlighter resistant, with Epson's DURABrite Ultra Ink. Offering great value, the inks are supplied individually, so you only ever have to replace the colour used. Plus, with XL cartridges you can print up to 2,600 black and 1,900 colour pages.
  • Desk-free printing
    Print from anywhere in the office with Wi-Fi connectivity or use Wi-Fi Direct to print from compatible wireless devices without a Wi-Fi network. You can also print via NFC with a simple tap of a compatible Android device on the printer.
Epson WorkForce Pro WF-4720DWF - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
25000 pages
Max Printing Speed
Up to 20 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
250 sheets
Output Trays Capacity
80 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
AC 120/230 V (50/60Hz)
42.5 cm x 37.8 cm x 24.9 cm
9.1 kg
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
25000 pages
Display Features
Touch screen
AirPrint Enabled
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (per cartridge)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3.8 pl
Printer Drivers / Emulations
EPSON ESC/P-R
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
250 sheets
80 sheets
Input tray - 250 sheets , ADF - 35 sheets , Output tray - 80 sheets
Speed Details
Printing: up to 34 ppm - B/W , Printing: up to 30 ppm - colour , Printing: up to 20 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - colour (ISO/IEC 24734) , Printing: up to 12 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 12 ppm (A4) - colour duplex (ISO/IEC 24734) , Scanning: 6 sec (A4) , Scanning: 12 sec (A4)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8 64-bit
Software Included
Drivers & Utilities
15 Watt
Power Consumption Standby
6.1 Watt
Power Consumption Sleep
1.2 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Limited warranty - 1 year - carry-in
42.5 cm
37.8 cm
24.9 cm
9.1 kg
