Epson WorkForce Pro WF-3720DWF Colour Ink-Jet Multifunction Printer
Quicklinx: DMWCWS00 Mfr#: C11CF24401
Style and substance
With its modern design, the compact WF-3720DWF is a great fit for the home or office. Its stylish and sleek design is complemented by a 6.8cm touchscreen.
Business quality
Even at high speeds, this 4-in-1 printer produces top quality, laser-like prints thanks to Epson's most advanced printhead technology, PrecisionCore. The WF-3720DWF is designed for business with double-sided printing, a 35 page automatic document feeder and 250 sheet paper tray. It also supports advanced Scan-to functions including Scan-to: Email, Cloud, FTP and Network.
Low running costs
Achieve professional, crisp and clear business documents that are water, smudge and highlighter resistant, with Epson's DURABrite Ultra Ink. Offering great value, the inks are supplied individually, so you only ever have to replace the colour used. Plus, with XL cartridges you can print up to three times more pages - that equates to 1,100 black and 950 colour pages4.
Print from anywhere
From your home or office, there's the option to use Wi-Fi connectivity or Wi-Fi Direct for printing from compatible wireless devices without a Wi-Fi network. You can also print via NFC with a simple tap of a compatible Android device on the printer . And there's Epson's free mobile printing apps and solutions including Email print, which allows you to send items to print from almost anywhere in the world .
  • Style and substance
    With its modern design, the compact WF-3720DWF is a great fit for the home or office. Its stylish and sleek design is complemented by touchscreen.
  • Business quality
    Even at high speeds, this 4-in-1 printer produces top quality, laser-like prints thanks to Epson's advanced printhead technology. The WF-3720DWF is designed for business with double-sided printing, an automatic document feeder and large paper tray. It also supports advanced scan-to functions, including scan-to: email, cloud, FTP and network.
  • Low running costs
    Achieve professional, crisp and clear business documents, that are water-, smudge- and highlighter-resistant, with Epson's DURABrite Ultra ink. Offering great value, the inks are supplied individually, so you only ever have to replace the color used. Plus, with XL cartridges you can print more pages.
  • Print from anywhere
    From your home or office, there's the possibility to use Wi-Fi connectivity or Wi-Fi Direct for printing from compatible wireless devices without a Wi-Fi network. You can also print via NFC with a simple tap of a compatible device on the printer.
Epson WorkForce Pro WF-3720DWF - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
20000 pages
Max Printing Speed
Up to 20 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 4800 x 2400 dpi (mono) / up to 4800 x 2400 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
250 sheets
Output Trays Capacity
80 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
AC 120/230 V (50/60Hz)
42.5 cm x 37.8 cm x 24.9 cm
8.6 kg
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
20000 pages
Display Features
Touch screen
AirPrint Enabled
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
800 nozzles (per cartridge)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3.8 pl
Printer Drivers / Emulations
EPSON ESC/P-R
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
250 sheets
80 sheets
Input tray - 250 sheets , ADF - 35 sheets , Output tray - 80 sheets
Speed Details
Printing: up to 33 ppm - B/W , Printing: up to 20 ppm - colour , Printing: up to 20 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734) , Printing: up to 10 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 7 ppm (A4) - colour duplex (ISO/IEC 24734) , Scanning: 6 sec (A4) , Scanning: 12 sec (A4)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8 64-bit
Software Included
Drivers & Utilities
15 Watt
Power Consumption Standby
6.4 Watt
Power Consumption Sleep
1.2 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Limited warranty - 1 year - carry-in
42.5 cm
37.8 cm
24.9 cm
8.6 kg
