Epson WorkForce DS-860N High Speed A4 Network Scanner
Quicklinx: 9JWDWS00 Mfr#: B11B222401BU
Performance and productivity
This scanner features a compact footprint and high speed scanning of up to 65ppm / 130ipm, even at 300dpi in colour. This, combined with hardware JPEG compression, makes large scan jobs faster to process. Its ReadyScan technology certifies mercury-free products and guarantees no warm-up time before scanning.
Seamless integration into document management and cloud systems
Epson Document Capture Pro makes it easy to integrate this business scanner into your document management system, speeding up workflow and enabling you to capture, convert and distribute scanned information into your document filing system. In addition, barcode recognition and Zonal OCR help automate large document processes. It can also Push Scan from the device, via network or USB, which helps to increase office productivity.
Scan software included
Epson Scan offers a wide selection of advanced document imaging features, such as text enhancement and automatic de-skew, which help improve efficiency and increase workload output. It also scans to .docx, .xlsx and .pptx.
Easy network sharing via Ethernet
Combined with Document Capture Pro, the Network Interface Unit allows you to customise 'scan to' job commands, such as 'scan-to-email', 'scan-to-Microsoft SharePoint ' or 'Scan-to-Cloud', among others, directly from the scanner's panel.
  • Productive A4 sheet-fed scanner
    The WorkForce DS-860N with Network Interface Unit is our fastest double-sided A4 sheet-fed scanner.
Epson WorkForce DS-860N - document scanner - desktop - LAN
Document scanner - desktop
Interface Type
LAN
Light Source
LED
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
65 ppm (mono) / 65 ppm (colour)
Max Document Size
216 mm x 356 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
6000 scans per day
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8, Microsoft Windows Server 2012 x64 Edition
30 cm x 16.6 cm x 15.8 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
LAN
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
65 ppm
Max Document Scan Speed Colour
65 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
65 ppm - black & white - A4 - 300 dpi , 130 ipm - duplex - black & white - A4 - 300 dpi , 65 ppm - colour - A4 - 300 dpi , 130 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
EPSON ReadyScan LED Technology, Automatic Separation, Barcode Detection, Auto Document Rotation, Punch Hole Removal, A3 stitching
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 356 mm
Automatic
80 sheets
Interfaces Details
USB 2.0 - Type B
Network interface panel
1 x USB cable
ENERGY STAR Certified
Software Included
EPSON Scan, EPSON Document Capture Pro
30 cm
16.6 cm
15.8 cm
4 kg
5 °C
35 °C
