Epson WorkForce DS-7500 A4 Flatbed Scanner
Quicklinx: 8FW8WS00 Mfr#: B11B205331BY
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 2.0
Compatibility: PC, Mac
£1,013.05 ex VAT
£1,215.66 inc VAT
The Epson WorkForce DS-7500 can handle large batches of documents in a single go, quickly and efficiently. With a scanning speed up to 40ppm/80ipm, this departmental scanner ensures fast and trouble-free scanning due to a 100-page ADF, one-pass duplex scanning, and Double Feed Detection.
Epson Document Capture Pro makes it easy to integrate high-speed scanning into your document management system, speeding up workflow and enabling users to capture, convert and distribute scanned information in virtually any document repository or document management system.
The scanner and its features can be shared between multiple users using the optional Network Interface Panel. Combined with Document Capture Pro, the Network Interface Panel allows users to benefit from Push Scan features and customise 'scan to' job functions, such as 'scan to email' or 'scan to Microsoft SharePoint ', among others. You can also benefit from its optional Push Scan features to increase productivity. These features enable complicated tasks to be carried out effortlessly, increasing users' acceptance and eliminating training requirements.
Epson ReadyScan LED technology eradicates warm-up time, guarantees an absence of mercury, and lowers power consumption. These elements, combined with an ENERGY STAR qualification, create an environment friendly device for your office workspace.
  • High-speed A4 document scanner
    Improve document workflow processes with this reliable A4 departmental scanner.
Epson WorkForce DS-7500 - document scanner - USB 2.0
Document scanner
Interface Type
USB 2.0
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Optical Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
216 mm x 1016 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
4000 scans per day
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4.x, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Citrix Presentation Server 4.5, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Citrix XenApp 5, Citrix XenApp 6
49.5 cm x 36 cm x 21.7 cm
9.8 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Document scanner
Interface Type
USB 2.0
A4 (210 x 297 mm)
Scanner
Input Type
Optical Resolution
1200 dpi x 1200 dpi
Automatic Duplexing
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Duty Cycle
4000 scans per day
Scanner Speed Details
80 ipm - colour , 80 ipm - black & white
Scanner Features
EPSON ReadyScan LED Technology, Remove Punch Hole, RGB Color Dropout
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 1016 mm
Plain paper
Automatic
100 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
Power Consumption Operational (Standby)
44.5 Watt (1.6 Watt)
Software Included
EPSON Scan, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for MAC, EPSON Document Capture Pro
49.5 cm
36 cm
21.7 cm
9.8 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
10 - 80%
Resources
The following resources are available for the Epson WorkForce DS-7500 A4 Flatbed Scanner
Interface: USB 2.0
Compatibility: PC
Compatibility: Mac
Brand: Epson
Price Range Ex VAT: £1000 - £1500
