Epson WorkForce DS-70000 A3 High Speed Scanner Kofax VRS Certified
Quicklinx: 8FWTWS00 Mfr#: B11B204331BY
The Epson WorkForce DS-70000 offers reliable, high-quality document capture, conversion and distribution into document management systems. This A3 document scanner is ideal for companies with heavy scanning needs.
Designed to fit into complex IT systems effortlessly, this high-performance device can handle large batches of documents in a single go, quickly and efficiently. With a scanning speed up to 70 ppm/140 ipm, this production scanner ensures heavy duty jobs are performed effortlessly. This scanner provides fast and trouble-free scanning due to a 200 A3-page ADF, one-pass duplex scanning, and double feed detection.
Document Capture Pro makes it easy to integrate this scanner into your document management system, speeding up workflow and enabling users to capture, convert and distribute scanned information in virtually any document repository or document management system.
Demo Video
  • A3 document scanner
    Improve document workflow processes with this reliable A3 production scanner.
Epson WorkForce DS-70000 - document scanner - USB 2.0
Document scanner
Interface Type
USB 2.0
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 16-bit (64k colours)
Grayscale / Color Depth (External)
24-bit (16.7 million colours) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
9600 dpi x 9600 dpi
Max Document Scan Speed
70 ppm (mono) / 70 ppm (colour)
Max Document Size
297 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
8000 scans per day
AC 120/230 V
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4.x, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Citrix Presentation Server 4.5, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6
64 cm x 52.2 cm x 28.9 cm
26.9 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Document scanner
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Grayscale Depth (External)
Colour Depth
Colour Depth (External)
48-bit colour
Optical Resolution
600 dpi x 600 dpi
9600 dpi x 9600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
70 ppm
Max Document Scan Speed Colour
70 ppm
Duty Cycle
8000 scans per day
Scanner Speed Details
140 ipm - colour , 140 ipm - black & white
Scanner Features
EPSON ReadyScan LED Technology, Remove Punch Hole, RGB Color Dropout
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 2540 mm
Plain paper
Automatic
200 sheets
Interfaces Details
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
AC 120/230 V
Power Consumption Operational (Standby)
79 Watt (1.5 Watt)
Software Included
EPSON Scan, EPSON Event Manager, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for MAC, EPSON Document Capture Pro
64 cm
52.2 cm
28.9 cm
26.9 kg
- 1 year - on-site
5 °C
35 °C
10 - 80%
8FWT Epson CoverPlus 3 Years onsite Warranty In Stock £568.60
8FWT Epson 3 Years CoverPlus Onsite For Workforce DS-50000 In Stock £451.36
Resources
The following resources are available for the Epson WorkForce DS-70000 A3 High Speed Scanner Kofax VRS Certified
