Epson WorkForce DS-60000N A3 Sheet fed Network Scanner
Quicklinx: 8FWRWS00 Mfr#: B11B204231BU
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A3 (297 x 420 mm)
Interface: Gigabit LAN
Compatibility: Mac, PC
£2,747.24 ex VAT
£3,296.68 inc VAT
Scanning up to 40 pages per minute, this efficient and reliable device meets the needs of medium and large businesses seeking enhanced document workflow. This scanner provides fast and trouble-free scanning due to a 200 A3-page ADF, one-pass duplex scanning, and double feed detection. Additionally, the 'scan to' functions offered by Document Capture Pro enable even greater productivity.
This scanner and its features can be shared between multiple users with the built-in Network Interface Panel. Combined with Document Capture Pro solutions, the Network Interface Panel allows users to benefit from Push Scan features and customise 'scan to' job functions, such as 'scan to email' or 'scan to Microsoft SharePoint ', among others. These features enable complicated tasks to be carried out effortlessly.
Document Capture Pro makes it easy to integrate this document scanner into your document management system, speeding up workflow and enabling users to capture, convert and distribute scanned information in virtually any document repository or document management system.
Document Capture Pro Server addresses companies who are looking for advanced push scan functions and other Document Capture Pro features on their shared devices without the need to install software on individual computers.
Epson ReadyScan LED technology eradicates warm-up time and lowers power consumption.
  • Efficient scanning
    With automatic duplexing and a robust duty cycle of 5,000 scans per day, the Epson WorkForce DS-60000N is designed for efficiency and reliability. Its 200-sheet feeder capacity ensures large batches can be handled with ease, making it a suitable choice for high-volume scanning environments.
  • High-quality imaging
    Achieve outstanding image clarity with a max optical resolution of 600 DPI and color scanning speeds of up to 40 ppm. The EPSON ReadyScan LED Technology, combined with RGB Color Dropout and Remove Punch Hole features, ensures high-quality scans without the wait.
  • Versatile connectivity
    Equipped with Gigabit LAN interface, the scanner supports a range of networking protocols including Ethernet, Fast Ethernet, and Gigabit Ethernet, offering flexible and fast connectivity options for seamless integration into any office network.
Epson WorkForce DS-60000N - document scanner - Gigabit LAN
Document scanner
Interface Type
Gigabit LAN
Additional Functions
Email
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 16-bit (64k colours)
Grayscale / Color Depth (External)
24-bit (16.7 million colours) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
9600 dpi x 9600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
297 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
5000 scans per day
AC 120/230 V
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6
64 cm x 52.2 cm x 28.9 cm
26.9 kg
Environmental Standards
ENERGY STAR Qualified
Document scanner
Interface Type
Gigabit LAN
Email
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Grayscale Depth (External)
Colour Depth
Colour Depth (External)
48-bit colour
Optical Resolution
600 dpi x 600 dpi
9600 dpi x 9600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
80 ipm - colour , 80 ipm - black & white
Scanner Features
EPSON ReadyScan LED Technology, Remove Punch Hole, RGB Color Dropout
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 2540 mm
Plain paper
Automatic
200 sheets
Interfaces Details
Gigabit LAN
ENERGY STAR Certified
AC 120/230 V
Power Consumption Operational (Standby)
82 Watt (4.1 Watt)
Software Included
EPSON Scan, EPSON Event Manager, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for MAC, EPSON Document Capture Pro
64 cm
52.2 cm
28.9 cm
26.9 kg
5 °C
35 °C
10 - 80%
8FWR Epson CoverPlus 3 Years onsite Warranty In Stock £473.33
8FWR Epson 3 Years CoverPlus Onsite For Workforce DS-50000 In Stock £375.74
Compatibility: Mac
Compatibility: PC
Brand: Epson
Price Range Ex VAT: £1500+
