Scanning up to 40 pages per minute, this efficient and reliable device meets the needs of medium and large businesses seeking enhanced document workflow. This scanner provides fast and trouble-free scanning due to a 200 A3-page ADF, one-pass duplex scanning, and double feed detection. Additionally, the 'scan to' functions offered by Document Capture Pro enable even greater productivity.
This scanner and its features can be shared between multiple users with the built-in Network Interface Panel. Combined with Document Capture Pro solutions, the Network Interface Panel allows users to benefit from Push Scan features and customise 'scan to' job functions, such as 'scan to email' or 'scan to Microsoft SharePoint ', among others. These features enable complicated tasks to be carried out effortlessly.
Document Capture Pro makes it easy to integrate this document scanner into your document management system, speeding up workflow and enabling users to capture, convert and distribute scanned information in virtually any document repository or document management system.
Document Capture Pro Server addresses companies who are looking for advanced push scan functions and other Document Capture Pro features on their shared devices without the need to install software on individual computers.
Epson ReadyScan LED technology eradicates warm-up time and lowers power consumption.
Efficient scanning
With automatic duplexing and a robust duty cycle of 5,000 scans per day, the Epson WorkForce DS-60000N is designed for efficiency and reliability. Its 200-sheet feeder capacity ensures large batches can be handled with ease, making it a suitable choice for high-volume scanning environments. -
High-quality imaging
Achieve outstanding image clarity with a max optical resolution of 600 DPI and color scanning speeds of up to 40 ppm. The EPSON ReadyScan LED Technology, combined with RGB Color Dropout and Remove Punch Hole features, ensures high-quality scans without the wait. -
Versatile connectivity
Equipped with Gigabit LAN interface, the scanner supports a range of networking protocols including Ethernet, Fast Ethernet, and Gigabit Ethernet, offering flexible and fast connectivity options for seamless integration into any office network.
- Epson WorkForce DS-60000N - document scanner - Gigabit LAN
- Document scanner
- Interface Type
- Gigabit LAN
- Additional Functions
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth
- 8-bit (256 colours) / 16-bit (64k colours)
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours) / 48-bit colour
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 9600 dpi x 9600 dpi
- Max Document Scan Speed
- 40 ppm (mono) / 40 ppm (colour)
- Max Document Size
- 297 mm x 2540 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 200 sheets
- Duty Cycle
- 5000 scans per day
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6
- 64 cm x 52.2 cm x 28.9 cm
- 26.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Document scanner
- Interface Type
- Gigabit LAN
- A3 (297 x 420 mm)
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 16-bit (64k colours)
- Colour Depth (External)
- 48-bit colour
- 600 dpi x 600 dpi
- Max Document Scan Speed B/W
- 40 ppm
- Max Document Scan Speed Colour
- 40 ppm
- Duty Cycle
- Scanner Speed Details
- 80 ipm - colour , 80 ipm - black & white
- Scanner Features
- EPSON ReadyScan LED Technology, Remove Punch Hole, RGB Color Dropout
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 297 mm x 2540 mm
- Plain paper
- Automatic
- 200 sheets
- Interfaces Details
- Gigabit LAN
- ENERGY STAR Certified
- Voltage Required
- AC 120/230 V
- Power Consumption Operational (Standby)
- 82 Watt (4.1 Watt)
- Software Included
- EPSON Scan, EPSON Event Manager, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for MAC, EPSON Document Capture Pro
- OS Required
- 64 cm
- 52.2 cm
- 28.9 cm
- 26.9 kg
- 5 °C
- 35 °C
- 10 - 80%
Epson CoverPlus 3 Years onsite Warranty | In Stock | £568.60 |
Epson 3 Years CoverPlus Onsite For Workforce DS-50000 | In Stock | £451.36 |
