Epson WorkForce DS-60000 A3 Flatbed Scanner Kofax VRS Certified
Quicklinx: 8FWQWS00 Mfr#: B11B204231BY
Scanning up to 40 pages per minute, this efficient and reliable device meets the needs of medium and large businesses seeking enhanced document workflow. This scanner provides fast and trouble-free scanning due to a 200 A3-page ADF, one-pass duplex scanning, and double feed detection. Additionally, the 'scan to' functions offered by Document Capture Pro enable even greater productivity.
Document Capture Pro makes it easy to integrate this scanner into your document management system, speeding up workflow and enabling users to capture, convert and distribute scanned information in virtually any document repository or document management systems.
This scanner and its features can be shared between multiple users using the optional Network Interface Panel. Combined with Document Capture Pro solutions, the Network Interface Panel allows users to benefit from Push Scan features and customise 'scan to' job functions, such as 'scan to email' or 'scan to Microsoft SharePoint ', among others. These features enable complicated tasks to be carried out effortlessly, increasing users' acceptance and eliminating training requirements.
Epson ReadyScan LED technology eradicates warm-up time, guarantees an absence of mercury, and lowers power consumption. These elements, combined with ENERGY STAR qualification, creates an environmentally friendly device.
  • Efficient scanning
    With automatic duplexing and a feeder capacity of 200 sheets, the Epson WorkForce DS-60000 streamlines document management by efficiently handling large volumes of paper, saving time and improving workflow.
  • High-quality imaging
    Achieve high image clarity with a max optical resolution of 600 DPI, ensuring that every detail is captured with precision. Whether scanning in color or black and white, documents are rendered with high quality.
  • Versatile compatibility
    Designed to work seamlessly with both Mac and PC, the Epson WorkForce DS-60000 offers flexible connectivity options through its USB 2.0 interface, making it a versatile choice for any office environment.
  • Eco-conscious operation
    ENERGY STAR certification signifies that the Epson WorkForce DS-60000 not only meets high standards of efficiency but also operates with a lower environmental impact, consuming only 79 W during operation.
Epson WorkForce DS-60000 - document scanner - USB 2.0
Document scanner
Interface Type
USB 2.0
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 16-bit (64k colours)
Grayscale / Color Depth (External)
24-bit (16.7 million colours) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
9600 dpi x 9600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
297 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
5000 scans per day
AC 120/230 V
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6
64 cm x 52.2 cm x 28.9 cm
26.9 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Document scanner
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Grayscale Depth (External)
Colour Depth
Colour Depth (External)
48-bit colour
Optical Resolution
600 dpi x 600 dpi
9600 dpi x 9600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
80 ipm - colour , 80 ipm - black & white
Scanner Features
EPSON ReadyScan LED Technology, Remove Punch Hole, RGB Color Dropout
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 2540 mm
Plain paper
Automatic
200 sheets
Interfaces Details
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
AC 120/230 V
Power Consumption Operational (Standby)
79 Watt (1.5 Watt)
Software Included
EPSON Scan, EPSON Event Manager, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for MAC, EPSON Document Capture Pro
64 cm
52.2 cm
28.9 cm
26.9 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
10 - 80%
8FWQ Epson CoverPlus 3 Years onsite Warranty In Stock £568.60
8FWQ Epson 3 Years CoverPlus Onsite For Workforce DS-50000 In Stock £451.36
Resources
The following resources are available for the Epson WorkForce DS-60000 A3 Flatbed Scanner Kofax VRS Certified
