This device is specially designed to accommodate documents individually, and is ideal for users with specific capture needs, such as scanning bound materials and thick or fragile documents. This scanner can be easily integrated into vertical applications thanks to TWAIN, ISIS and WIA support, as well as Document Capture Pro connectors.
High-quality scanning results are ensured by CCD technology and innovating imaging features, such as Book Spine Correction, and improved colour dropout/enhance powered by Epson Scan. In addition, Document Capture Pro makes it easy to treat scanned data before its conversion and distribution in virtually any document repository or document management system.
This scanner and its features can be shared between multiple users using the optional Network Interface Panel. Combined with Document Capture Pro solutions, the Network Interface Panel allows users to benefit from Push Scan features and customise ‘scan to’ job functions such as ‘scan to email’ or ‘scan to Microsoft SharePoint®’, among others*2. These features enable complicated tasks to be carried out effortlessly.
Epson ReadyScan LED technology eradicates warm-up time, guarantees an absence of mercury, and lowers power consumption. These elements, combined with ENERGY STAR qualification*1, creates an environmentally friendly device.
- Epson WorkForce DS-5500 - flatbed scanner - USB 2.0
- Flatbed scanner
- Interface Type
- USB 2.0
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Optical Resolution
- 1200 dpi x 1200 dpi
- Max Document Size
- 210 mm x 297 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Manual
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4.x, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Citrix Presentation Server 4.5, Apple MacOS X 10.5.x, Apple MacOS X 10.6.x, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6
- 49.5 cm x 36 cm x 12.9 cm
- 6 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Flatbed scanner
- Interface Type
- USB 2.0
- A4 (210 x 297 mm)
Scanner
- Input Type
- Scanner Speed Details
- 8 sec/scan - colour , 8 sec/scan - black & white
- Scanner Features
- EPSON ReadyScan LED Technology, Remove Punch Hole, RGB Color Dropout
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 210 mm x 297 mm
- Plain paper
- Manual
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Voltage Required
- Power Consumption Operational (Standby)
- 17.5 Watt (1.6 Watt)
- Software Included
- EPSON Scan, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for MAC, EPSON Document Capture Pro
- OS Required
- 49.5 cm
- 36 cm
- 12.9 cm
- 6 kg
- Limited warranty - 1 year - on-site
- 5 °C
- 35 °C
- 10 - 80%
Epson CoverPlus 3 Years onsite Warranty | In Stock | £200.90 |
