Epson WorkForce DS-50000 A3 Flatbed Scanner
Quicklinx: 8FWMWS00 Mfr#: B11B204131BY
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: A3 (297 x 420 mm)
Interface: USB 2.0
Compatibility: Mac, PC
£1,265.40 ex VAT
£1,518.48 inc VAT
This device is specially designed to accommodate documents individually, and is ideal for users with specific capture needs, such as scanning bound materials and thick or fragile documents. This scanner can be easily integrated into vertical applications thanks to TWAIN, ISIS and WIA support, as well as Document Capture Pro connectors.
High-quality scanning results are ensured by CCD technology and innovating imaging features, such as Book Spine Correction, and improved colour dropout/enhance powered by Epson Scan. In addition, Document Capture Pro makes it easy to treat scanned data before its conversion and distribution in virtually any document repository or document management system.
This scanner and its features can be shared between multiple users using the optional Network Interface Panel. Combined with Document Capture Pro solutions, the Network Interface Panel allows users to benefit from Push Scan features and customise ‘scan to’ job functions such as ‘scan to email’ or ‘scan to Microsoft SharePoint®’, among others*2. These features enable complicated tasks to be carried out effortlessly.
Epson ReadyScan LED technology eradicates warm-up time, guarantees an absence of mercury, and lowers power consumption. These elements, combined with ENERGY STAR qualification*1, creates an environmentally friendly device.
  • A3 document scanner
    High-performance A3 flatbed for capturing large, bound or fragile documents.
Epson WorkForce DS-50000 - flatbed scanner - USB 2.0
Flatbed scanner
Interface Type
USB 2.0
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 16-bit (64k colours)
Grayscale / Color Depth (External)
24-bit (16.7 million colours) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
9600 dpi x 9600 dpi
Scan Speed
4 sec / page
Supported Document Type
Plain paper
Document Feeder Type
Manual
AC 120/230 V
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6
Microsoft Certification
Compatible with Windows 7
64 cm x 46.8 cm x 15.6 cm
14.8 kg
Environmental Standards
ENERGY STAR Qualified
Flatbed scanner
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Grayscale Depth (External)
Colour Depth
Colour Depth (External)
48-bit colour
Optical Resolution
600 dpi x 600 dpi
9600 dpi x 9600 dpi
Scan Speed
4 sec / page
Scanner Features
EPSON ReadyScan LED Technology, Remove Punch Hole, RGB Color Dropout
TWAIN, ISIS, WIA
Media Handling
Plain paper
Manual
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
AC 120/230 V
Power Consumption Operational (Standby)
25.5 Watt (1.5 Watt)
Software Included
EPSON Scan, EPSON Event Manager, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for MAC, EPSON Document Capture Pro
64 cm
46.8 cm
15.6 cm
14.8 kg
5 °C
35 °C
10 - 80%
8FWM Epson CoverPlus 3 Years onsite Warranty In Stock £473.33
8FWM Epson 3 Years CoverPlus Onsite For Workforce DS-50000 In Stock £375.74
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Epson
Price Range Ex VAT: £1000 - £1500
