Epson WorkForce DS-360W Duplex A4 Document Scanner
Quicklinx: CPTSWS00 Mfr#: B11B242401BY
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 3.0, Wi-Fi(n)
Compatibility: Mac, PC
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£273.27 ex VAT
£327.92 inc VAT
It's easy to scan anywhere with the fastest portable business scanner on the market, thanks to a built-in battery and wireless connectivity
  • Portable scanner with Wi-Fi and battery
    It's easy to scan anywhere with the fastest portable business scanner on the market , thanks to a built-in battery and wireless connectivity.
Epson WorkForce DS-360W - document scanner - desktop - USB 3.0, Wi-Fi(n)
Document scanner - desktop
Interface Type
USB 3.0, Wi-Fi(n)
Additional Functions
Email, scan to print, scan to network share, scan to FTP, scan to folder, scan to SharePoint
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Optical Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
25 ppm (mono) / 25 ppm (colour)
Max Document Size
215.9 mm x 1117.6 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
20 sheets
Duty Cycle
500 scans per day
AC 100 - 240 V (50/60 Hz)
Microsoft Windows XP, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x, Microsoft Windows Server 2012 (64-bit)
28.8 cm x 8.9 cm x 6.7 cm
1.3 kg
1-year warranty
Interface Type
USB 3.0, Wi-Fi(n)
A4 (210 x 297 mm)
Scanner
Input Type
Optical Resolution
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
25 ppm
Duty Cycle
500 scans per day
Scanner Speed Details
25 ppm - black & white - 300 dpi , 25 ppm - colour - 300 dpi
Scan File Formats
BMP, JPEG, TIFF, PDF
TWAIN
Media Handling
Max Document Size
Plain paper
Supported Document Size Details
ADF - up to 215.9 x 1117.6 mm
Automatic
20 sheets
USB 3.0
1 x USB cable
Power Consumption Operational (Standby)
8 Watt
Power Consumption Stand by
0.3 Watt
Software Included
Presto! BizCard, EPSON Document Capture Pro, EPSON Document Capture, EPSON Scan 2
28.8 cm
8.9 cm
6.7 cm
1.3 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
15 - 80%
Interface: USB 3.0
Interface: Wi-Fi(n)
Compatibility: Mac
Compatibility: PC
Brand: Epson
Price Range Ex VAT: 150 - 300
