It's easy to scan and manage your paperwork on the go with the DS-310. Its compact and lightweight design means that it's ideal for carrying in a bag or even storing in a drawer. Give yourself the flexibility to scan what you need, when you need it. With the DS-310, you can capture documents at 300dpi in color and monochrome with absolute ease. When it comes to media, it's almost limitless with both single and double-sided scanning, and the ability to handle card and paper between 52 and 230gsm.
Fast, portable business scanner
Scan a wide range of documents on the go with the fastest portable business scanner on the market , with Super Speed USB 3.0 connectivity.
- Epson WorkForce DS-310 - document scanner - desktop - USB 3.0
- Document scanner - desktop
- Interface Type
- USB 3.0
- Additional Functions
- Scan to FTP, scan to folder, scan to print, scan to SharePoint
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 25 ppm (mono) / 25 ppm (colour)
- Max Document Size
- 215.9 mm x 1117.6 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card, plastic card, post card, envelope
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 20 sheets
- Duty Cycle
- 500 scans per day
- Power
- AC 100/120/230 V (50 - 60 Hz)
- System Requirements
- Apple MacOS X 10.10.x, Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Apple MacOS X 10.9.x, Windows 10, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP, Microsoft Windows XP SP2 or later, Microsoft Windows Server 2003 R2
- 28.8 cm x 8.9 cm x 5.1 cm
- 1.1 kg
- 1-year warranty
- Interface Type
- USB 3.0
- A4 (210 x 297 mm)
Scanner
- Input Type
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Max Document Scan Speed B/W
- 25 ppm
- Max Document Scan Speed Colour
- 25 ppm
- Duty Cycle
- 500 scans per day
- Scanner Speed Details
- 25 ppm - black & white - A4 - 300 dpi , 50 ipm - duplex - black & white - A4 - 300 dpi , 25 ppm - colour - A4 - 300 dpi , 50 ipm - duplex - colour - A4 - 300 dpi
- Scanner Features
- Unsharp Mask, Noise Reduction
- Scan File Formats
- JPEG, BMP, TIFF, PDF
- ISIS
Media Handling
- Max Document Size
- Automatic
- 20 sheets
- Interfaces Details
- USB 3.0
- Cables Included
- 1 x USB cable
- Voltage Required
- Power Consumption Operational (Standby)
- 8 watt
- Power Consumption Stand by
- 0.3 watt
- Software Included
- EPSON Document Capture, EPSON Document Capture Pro, EPSON Scan 2, NewSoft Presto! BizCard 5.6
- OS Required
- 28.8 cm
- 8.9 cm
- 5.1 cm
- 1.1 kg
- Limited warranty - 1 year - on-site
- 5 °C
- 35 °C
- 15 - 80%
