Epson WorkForce DS-310 Duplex A4 Document Scanner
Quicklinx: CPTRWS00 Mfr#: B11B241401BY
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 3.0
Compatibility: Mac, PC
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Hurry, only 2 left in stock!
£231.27 ex VAT
£277.52 inc VAT
It's easy to scan and manage your paperwork on the go with the DS-310. Its compact and lightweight design means that it's ideal for carrying in a bag or even storing in a drawer. Give yourself the flexibility to scan what you need, when you need it. With the DS-310, you can capture documents at 300dpi in color and monochrome with absolute ease. When it comes to media, it's almost limitless with both single and double-sided scanning, and the ability to handle card and paper between 52 and 230gsm.
  • Fast, portable business scanner
    Scan a wide range of documents on the go with the fastest portable business scanner on the market , with Super Speed USB 3.0 connectivity.
Epson WorkForce DS-310 - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Additional Functions
Scan to print, scan to FTP, scan to folder, scan to SharePoint
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
25 ppm (mono) / 25 ppm (colour)
Max Document Size
215.9 mm x 1117.6 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card, envelope, post card
Document Feeder Type
Automatic
Document Storage Capacity
20 sheets
Duty Cycle
500 scans per day
AC 100/120/230 V (50 - 60 Hz)
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x
28.8 cm x 8.9 cm x 5.1 cm
1.1 kg
1-year warranty
Interface Type
USB 3.0
A4 (210 x 297 mm)
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
25 ppm
Duty Cycle
500 scans per day
Scanner Speed Details
25 ppm - black & white - A4 - 300 dpi , 50 ipm - duplex - black & white - A4 - 300 dpi , 25 ppm - colour - A4 - 300 dpi , 50 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
Noise Reduction, Unsharp Mask
Scan File Formats
BMP, JPEG, TIFF, PDF
ISIS
Media Handling
Max Document Size
Automatic
20 sheets
USB 3.0
1 x USB cable
Power Consumption Operational (Standby)
8 Watt
Power Consumption Stand by
0.3 Watt
Software Included
EPSON Document Capture Pro, EPSON Document Capture, EPSON Scan 2, NewSoft Presto! BizCard 5.6
28.8 cm
8.9 cm
5.1 cm
1.1 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
15 - 80%
Interface: USB 3.0
Compatibility: Mac
Compatibility: PC
Brand: Epson
Price Range Ex VAT: 150 - 300
