Epson WorkForce DS-310 Duplex A4 Document Scanner
Quicklinx: CPTRWS00 Mfr#: B11B241401BY
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
It's easy to scan and manage your paperwork on the go with the DS-310. Its compact and lightweight design means that it's ideal for carrying in a bag or even storing in a drawer. Give yourself the flexibility to scan what you need, when you need it. With the DS-310, you can capture documents at 300dpi in color and monochrome with absolute ease. When it comes to media, it's almost limitless with both single and double-sided scanning, and the ability to handle card and paper between 52 and 230gsm.
  • Fast, portable business scanner
    Scan a wide range of documents on the go with the fastest portable business scanner on the market , with Super Speed USB 3.0 connectivity.
Epson WorkForce DS-310 - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Additional Functions
Scan to FTP, scan to folder, scan to print, scan to SharePoint
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
25 ppm (mono) / 25 ppm (colour)
Max Document Size
215.9 mm x 1117.6 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card, post card, envelope
Document Feeder Type
Automatic
Document Storage Capacity
20 sheets
Duty Cycle
500 scans per day
AC 100/120/230 V (50 - 60 Hz)
Apple MacOS X 10.10.x, Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Apple MacOS X 10.9.x, Windows 10, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP, Microsoft Windows XP SP2 or later, Microsoft Windows Server 2003 R2
28.8 cm x 8.9 cm x 5.1 cm
1.1 kg
1-year warranty
Interface Type
USB 3.0
A4 (210 x 297 mm)
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
25 ppm
Duty Cycle
500 scans per day
Scanner Speed Details
25 ppm - black & white - A4 - 300 dpi , 50 ipm - duplex - black & white - A4 - 300 dpi , 25 ppm - colour - A4 - 300 dpi , 50 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
Unsharp Mask, Noise Reduction
Scan File Formats
JPEG, BMP, TIFF, PDF
ISIS
Media Handling
Max Document Size
Automatic
20 sheets
Interfaces Details
USB 3.0
1 x USB cable
Power Consumption Operational (Standby)
8 watt
Power Consumption Stand by
0.3 watt
Software Included
EPSON Document Capture, EPSON Document Capture Pro, EPSON Scan 2, NewSoft Presto! BizCard 5.6
28.8 cm
8.9 cm
5.1 cm
1.1 kg
Limited warranty - 1 year - on-site
5 °C
35 °C
15 - 80%
