Epson WorkForce DS-1660W Duplex Document Scanner
Quicklinx: CTMSWS00 Mfr#: B11B244401BY
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: Wi-Fi(n), USB 3.0
Compatibility: Mac, PC
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Hurry, only 1 left in stock!
£234.64 ex VAT
£281.56 inc VAT
Intelligent features
Smart colour and image adjustments, including auto crop, skew correction, blank page and background removal, with Epson's Image Processing Technology. With long document mode it's possible scan over three metres (3048mm) of paper single sided.
Flexible placement
The Wi-Fi and Wi-Fi Direct connectivity on the DS-1660W provide extra convenience to organisations wanting to deploy a dedicated scanning solution that can be accessed easily by many people. With NFC enabled, use the Epson Scan App to take control with your mobile device - then edit and improve digital images before saving and sharing.
Boost your office efficiency
One of the fastest scanners in its class with a 25ppm scan speed. USB 3.0 connectivity means there is no slow down, even when scanning at 300dpi high resolution. Scan both sides of a page with double-sided scanning capability for greater convenience. Create up to 30 jobs with the optional network panel and scan directly to server locations, cloud services and Microsoft SharePoint. Included Epson software enables dual image output; scan once and send to two different destinations. The DS-1660W also encourages easy, one-touch scanning to folders, email, online storage accounts and more.
  • Intelligent features
  • Flexible placement
  • Boost your office efficiency
    One of the fastest scanners in its class with a 25ppm scan speed. USB 3.0 connectivity means there is no slow down, even when scanning at 300dpi high resolution. Scan both sides of a page with double-sided scanning capability for greater convenience. Included Epson software enables dual image output; scan once and send to two different destinations. The DS-1660W also encourages easy, one-touch scanning to folders, email, online storage accounts and more.
Epson WorkForce DS-1660W - document scanner - desktop - USB 3.0, Wi-Fi(n)
Document scanner - desktop
Interface Type
USB 3.0, Wi-Fi(n)
Light Source
LED
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Optical Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
25 ppm (mono) / 25 ppm (colour)
Max Document Size
210 mm x 3048 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1500 scans per day
Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.6.x, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Apple MacOS X 10.9.x, Windows 10
45.1 cm x 31.5 cm x 12 cm
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 3.0, Wi-Fi(n)
A4 (210 x 297 mm)
Scanner
Input Type
Optical Resolution
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
25 ppm
Duty Cycle
1500 scans per day
Scanner Speed Details
25 ppm - black & white - 300 dpi , 10 ipm - duplex - black & white - 300 dpi , 25 ppm - colour - 300 dpi , 10 ipm - duplex - colour - 300 dpi
Scanner Features
EPSON ReadyScan LED Technology, blank page skipping, Text Enhancement, Auto Document Rotation, skew correction, OCR Text Recognition
Scan File Formats
JPEG, TIFF, PDF
TWAIN
Media Handling
Max Document Size
210 mm x 3048 mm
Plain paper
Automatic
50 sheets
Interfaces Details
USB 3.0
1 x USB cable
ENERGY STAR Certified
Software Included
EPSON Scan, EPSON Document Capture Pro
45.1 cm
31.5 cm
12 cm
Limited warranty - 1 year - on-site
10 °C
35 °C
20 - 80%
Sound Emission
55 dBA
Interface: Wi-Fi(n)
Interface: USB 3.0
Compatibility: Mac
Compatibility: PC
Brand: Epson
