Intelligent features
Smart colour and image adjustments, including auto crop, skew correction, blank page and background removal, with Epson's Image Processing Technology. With long document mode it's possible scan over three metres (3048mm) of paper single sided.
Flexible placement
The Wi-Fi and Wi-Fi Direct connectivity on the DS-1660W provide extra convenience to organisations wanting to deploy a dedicated scanning solution that can be accessed easily by many people. With NFC enabled, use the Epson Scan App to take control with your mobile device - then edit and improve digital images before saving and sharing.
Boost your office efficiency
One of the fastest scanners in its class with a 25ppm scan speed. USB 3.0 connectivity means there is no slow down, even when scanning at 300dpi high resolution. Scan both sides of a page with double-sided scanning capability for greater convenience. Create up to 30 jobs with the optional network panel and scan directly to server locations, cloud services and Microsoft SharePoint. Included Epson software enables dual image output; scan once and send to two different destinations. The DS-1660W also encourages easy, one-touch scanning to folders, email, online storage accounts and more.
                Intelligent featuresSmart colour and image adjustments, including auto crop, skew correction, blank page and background removal, with Epson's Image Processing Technology. With long document mode it's possible scan over three metres (3048mm) of paper single sided.
                Flexible placementThe Wi-Fi and Wi-Fi Direct connectivity on the DS-1660W provide extra convenience to organisations wanting to deploy a dedicated scanning solution that can be accessed easily by many people. With NFC enabled, use the Epson Scan App to take control with your mobile device - then edit and improve digital images before saving and sharing.
                Boost your office efficiencyOne of the fastest scanners in its class with a 25ppm scan speed. USB 3.0 connectivity means there is no slow down, even when scanning at 300dpi high resolution. Scan both sides of a page with double-sided scanning capability for greater convenience. Included Epson software enables dual image output; scan once and send to two different destinations. The DS-1660W also encourages easy, one-touch scanning to folders, email, online storage accounts and more.
- Epson WorkForce DS-1660W - document scanner - desktop - USB 3.0, Wi-Fi(n)
- Document scanner - desktop
- Interface Type
- USB 3.0, Wi-Fi(n)
- Light Source
- LED
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Optical Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 25 ppm (mono) / 25 ppm (colour)
- Max Document Size
- 210 mm x 3048 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 1500 scans per day
- System Requirements
- Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.6.x, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Apple MacOS X 10.9.x, Windows 10
- 45.1 cm x 31.5 cm x 12 cm
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 3.0, Wi-Fi(n)
- A4 (210 x 297 mm)
Scanner
- Input Type
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 25 ppm
- Max Document Scan Speed Colour
- 25 ppm
- Duty Cycle
- Scanner Speed Details
- 25 ppm - black & white - 300 dpi , 10 ipm - duplex - black & white - 300 dpi , 25 ppm - colour - 300 dpi , 10 ipm - duplex - colour - 300 dpi
- Scanner Features
- EPSON ReadyScan LED Technology, blank page skipping, Text Enhancement, Auto Document Rotation, skew correction, OCR Text Recognition
- Scan File Formats
- JPEG, TIFF, PDF
- TWAIN
Media Handling
- Max Document Size
- 210 mm x 3048 mm
- Plain paper
- Automatic
- 50 sheets
- Interfaces Details
- USB 3.0
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Software Included
- EPSON Scan, EPSON Document Capture Pro
- OS Required
- 45.1 cm
- 31.5 cm
- 12 cm
- Limited warranty - 1 year - on-site
- 10 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 55 dBA
