Epson WorkForce AL-M300DTN A4 Mono Laser Printer
Quicklinx: 8P0TWS00 Mfr#: C11CC72031BY
The Epson WorkForce AL-MX200DNF is network-ready for sharing across small workgroups, but can also be used on individual user desktops thanks to its compact size. It also features a retractable paper tray which, when the printer is not in use, can be folded away.
The Epson WorkForce AL-MX200DNF's toner cartridge is easy to replace. Users simply insert the cartridge into the toner slot and twist to connect. No mess, no hassle, no problem.
In addition, users can print and share from anywhere in the office, thanks to Epson's mobile printing app, Epson iPrint. This easy-to-use application allows workers to print wirelessly from smartphones and tablet PCs* .
Documents can be scanned straight to USB, ideal for quick document sharing or saving files to portable memory devices. In addition, documents can be scanned and sent directly to email accounts, ensuring important paper documents can be shared instantly to members of staff anywhere.
With the Epson WorkForce AL-MX200DNF, businesses can concentrate on their work, without any downtime, as its high-performance, user-friendly features offers great peace of mind and productivity.
Epson WorkForce AL-MX200DNF - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
LED (monochrome)
Monthly Duty Cycle (max)
30000 impressions
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 30 ppm
Max Printing Resolution
Up to 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
250 sheets
Output Trays Capacity
125 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network
AC 230 V (50/60Hz)
42 cm x 39.8 cm x 36.5 cm
12 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
LED - monochrome
30000 impressions
Display
4 lines
Standard Memory
256 MB 256 MB
Max Supported Memory
256 MB 256 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Up to 1200 dpi
Max Printing Speed
Up to 30 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3
Automatic Duplexing
First Print Out Time B/W
7 sec
Scanning
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
99 station(s)
Document & Media Handling
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
125 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) , ADF - 50 sheets , Output tray - 125 sheets
Speed Details
Printing: up to 30 ppm - B/W , Copying: up to 20 ppm - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, Windows 8
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
500 Watt
Power Consumption Standby
55 Watt
Power Consumption Sleep
8 Watt
Warm-Up Time
45 sec
First Copy Out Time B/W
20 sec
Consumables Included
1 x toner cartridge (black)
EN 61000-3-2, EN55022, EN 61000-3-3, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
42 cm
39.8 cm
36.5 cm
12 kg
Shipping Width
51 cm
Shipping Depth
55.4 cm
Shipping Height
49.3 cm
Shipping Weight
15 kg
Sound Emission
25.5 dBA (idle) / 54.5 dBA (operating)
10 °C
32 °C
10 - 85%
Ink (1)
8P0T Epson AL-M200/MX200 Standard Capacity Toner Cartridge 2.5k In Stock £72.72
Other bundles (1)
8P0T C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
