Fast, high-quality and low-cost printing
The AL-C300N delivers ISO print speeds of up to 31ppm, in both mono and colour¹. Prints are delivered at 1200 x 1200 dpi for high-quality results, and 1GB of RAM as standard saves time on repeated print jobs.
Easy to use and energy efficient
Its LCD screen makes it easy to control advanced functions. A high toner yield of up to 7,300 pages in black and 8,800 pages in colour² not only makes your supplies go further, but it also means less time is wasted changing supplies. A double pack of black toner is also available. Not only is the AL-C300N ENERGY STAR-qualified, it also has a very low power used of 1.3W when in deep sleep mode.
High durability
It has a duty cycle of up to 120,000 pages³, so businesses can be confident that their investment in the Epson range is a sound one.
Advanced connectivity, integration and security
PDL printer emulations including PCL6, PostScript 3 and PDF 1.7, along with the advanced IPv6 protocol and gigabit Ethernet support, make this printer ideal for business environments. Advanced IPSec and SSL support help improve security when printing sensitive materials, and print securely and confidentially with Email Print for Enterprise compatiblity4.
Fast A4 colour laser
A compact and affordable A4 colour laser printer with easy network integration, delivering fast and high-quality results.
- Epson AL-C300N - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 27.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 31 ppm - B/W , Up to 31 ppm - colour
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- 750 MHz
- RAM Installed (Max)
- 1 GB (1 GB)
- Language Simulation
- PCL 5E, PCL 5C, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 120000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.6.8 or later, Windows 8, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2, Windows 8.1
- 1-year warranty
- 44.4 cm x 54.4 cm x 35 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- First Print Out Time B/W
- 12 sec
- Media Handling
- Processor
- 750 MHz
RAM
- 1 GB / 1 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), F4
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm)
- Media Weight
- 60 g/m² - 210 g/m²
- 350 sheets
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 200 sheets
Duty Cycle
- 120000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP, IPP, HTTP
- IPsec, 802.1x, PING
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- EN 61000-3-2, EN55022, IEC 61000-4-11, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN 61000-3-3, EN55024, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
- 475 Watt
- Power Consumption Stand by
- 69 Watt
- Power Consumption Sleep
- 2.8 Watt
- Software Included
- Drivers & Utilities, EpsonNet Config
- OS Required
- Limited warranty - 1 year - on-site
- 10 °C
- 30 °C
- 15 - 85%
- Sound Emission (Idle)
- 39 dBA
- Sound Emission (Operating)
- 54 dBA
- 44.4 cm
- 54.4 cm
- 35 cm
- 27.5 kg
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
