Multi-function impact printer
This fits the bill when you need fast, reliable multi-part printing for receipts, journals and slips.
- Epson TM U950 - receipt printer - B/W - dot-matrix
- Printer Type
- Receipt printer - dot-matrix - 9 pin - B/W
- 5.6 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm), Roll (7 cm)
- Print Speed
- Up to 311 char/sec - normal , Up to 233 char/sec - normal
- Max Resolution (B&W)
- 16.7 cpi
- Interface
- Serial
- Media Type
- Plain paper, continuous forms
- Enclosure Colour
- Cool white
- 25.1 cm x 29.8 cm x 19.5 cm
- Printer Type
- Receipt printer - dot-matrix - 9 pin - monochrome
- Enclosure Colour
- Cool white
Printer
- Print Speed
- Up to 311 char/sec - normal - 16.7 cpi , Up to 233 char/sec - normal - 12.5 cpi
- Connectivity Technology
- Wired
- Interface
- Serial
- 16.7 cpi
- Character Sizes (mm)
- 1.6 x 3.1 mm, 1.3 x 3.1 mm
- Columns
- 30, 66, 40, 88
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- Media Sizes
- Roll Maximum Outer Diameter
- 83 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (6.95 cm) , 1 x manual - 1 sheet - A4 (210 x 297 mm)
- Max Sheets in Multi-Part Form
- 5
- Connections
- 1 x RS-232
- MTBF
- 180,000 hour(s)
- FCC Class A certified, CSA, UL, VCCI Class A ITE
- 25.1 cm
- 29.8 cm
- 19.5 cm
- 5.6 kg
Ink (1)
Epson ERC 31B - Print ribbon - | In Stock | £3.43 |
Other bundles (1)
Epson Power Supply 100-230V | In Stock | £41.36 |
