Epson TM-U950 Mono Dot-Matrix Receipt Printer
Quicklinx: F3JQWS00 Mfr#: C31C151283
2.5ST IMPACT PACKAGE PRINTER; Serial;Epson Cool White (ECW); no Power Supply.
  • Multi-function impact printer
    This fits the bill when you need fast, reliable multi-part printing for receipts, journals and slips.
Epson TM U950 - receipt printer - B/W - dot-matrix
Printer Type
Receipt printer - dot-matrix - 9 pin - B/W
5.6 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm), Roll (7 cm)
Print Speed
Up to 311 char/sec - normal , Up to 233 char/sec - normal
Max Resolution (B&W)
16.7 cpi
Serial
Media Type
Plain paper, continuous forms
Enclosure Colour
Cool white
25.1 cm x 29.8 cm x 19.5 cm
Printer Type
Receipt printer - dot-matrix - 9 pin - monochrome
Enclosure Colour
Cool white
Printer
Print Speed
Up to 311 char/sec - normal - 16.7 cpi , Up to 233 char/sec - normal - 12.5 cpi
Wired
Serial
16.7 cpi
Character Sizes (mm)
1.6 x 3.1 mm, 1.3 x 3.1 mm
Columns
30, 66, 40, 88
Media Handling
Media Type
Media Size Class
A4
Max Media Size
Media Sizes
Roll Maximum Outer Diameter
83 mm
Media Feeders
1 x manual - 1 roll - Roll (6.95 cm) , 1 x manual - 1 sheet - A4 (210 x 297 mm)
Max Sheets in Multi-Part Form
5
1 x RS-232
MTBF
180,000 hour(s)
FCC Class A certified, CSA, UL, VCCI Class A ITE
25.1 cm
29.8 cm
19.5 cm
5.6 kg
F3JQ Epson Power Supply 100-230V In Stock £40.86
