Easy-to-use impact printer
If you need a hard worker that's easy to use and versatile, this is the ideal impact receipt printer.
- Epson TM U220PB - receipt printer - two-colour (monochrome) - dot-matrix
- Printer Type
- Receipt printer - dot-matrix - 9 pin - two-colour (monochrome)
- 2.5 kg
- Max Media Size
- Roll (7.6cm)
- Max Media Size (Custom)
- 76 mm
- Print Speed
- Up to 6 lines/sec - max speed
- Max Resolution (B&W)
- 17.8 cpi
- Cutter
- Interface
- Parallel
- Language Simulation
- EPSON ESC/POS
- Media Type
- Receipt paper
- Total Media Capacity
- 1 roll
- Enclosure Colour
- Cool white
- 1-year warranty
- 16 cm x 24.8 cm x 13.9 cm
- Printer Type
- Enclosure Colour
- Cool white
Printer
- Print Speed
- Up to 6 lines/sec - max speed - 16 cpi
- Built-in Devices
- Cutter
- Connectivity Technology
- Wired
- Interface
- Parallel
- 17.8 cpi
- EPSON ESC/POS
- Character Sizes (mm)
- 1.2 x 3.1 mm, 1.6 x 3.1 mm
- Columns
- 33, 35, 40, 42
- Auto Cutter
- Repeating Printing
- 1 copy
Media Handling
- Media Type
- Receipt paper
- Max Media Size
- Roll (7.6cm)
- 76 mm
- Media Sizes
- Roll (7 cm), Roll (7.6cm), Roll (5.8 cm)
- Media Thickness Range
- 0.06 mm - 0.085 mm
- Roll Maximum Outer Diameter
- 83 mm
- 1 roll
- Media Feeders
- 1 x manual - 1 roll - Roll (7.6cm)
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x parallel
- Mounting Kit
- Optional
- MTBF
- 180,000 hour(s)
- Wall mountable
- FCC Class A certified, CSA, UL, TUV, EN 60950, VCCI Class A ITE, EN55024, EN55022 Class B, AS/NZ 3548 Class B
- Power Device
- Power adapter - external
- 31 Watt
- Power Consumption Stand by / Sleep
- 2.2 Watt
- Limited warranty - 1 year
- 0 °C
- 50 °C
- 10 - 90%
- 16 cm
- 24.8 cm
- 13.9 cm
- 2.5 kg
Ink (1)
Other bundles (2)
Epson Power Supply 100-230V | In Stock | £37.91 |
Epson Ethernet Interface Card UB-E04 | In Stock | £41.93 |
