Product
Epson TM T88V Monochrome Thermal Line Receipt Printer
Quicklinx: 8RKNWS00 Mfr#: C31CA85012
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Thermal transfer
12 left in stock
£195.68 ex VAT
£234.81 inc VAT
Actual print speed is an impressive and efficient 300mm per second while multiple grey scale printing enables better representation of logos and graphic images. The TM-T88V works on several platforms, so it's simple to integrate into your network and it also comes with in-built USB IF which means easy migration to USB in the future.
This is a highly reliable and easy-to-use POS printer, but with the interest of the customer being paramount, we have included a 4-year warranty as standard.
This product meets the strict ENERGY STARĀ® guidelines set by the European Commission. Epson is a global manufacturer committed to protecting the environment for future generations by offering a range of ENERGY STARĀ® products. This is achieved by significantly reducing electricity usage, which saves energy, money and the environment, without compromising quality.
  • ENERGY STAR receipt printer
    Go greener with the world's first ENERGY STAR qualified POS thermal receipt printer.
Epson TM T88V - receipt printer - monochrome - thermal line
Printer Type
Receipt printer - thermal line - monochrome
1.6 kg
Max Media Size
Roll (8 cm)
Max Media Size (Custom)
80 mm
Print Speed
Up to 300 mm/sec - max speed
USB, serial
Barcodes
Code 93, Code 39, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, Codabar, Code 128, PDF417, ITF
Media Type
Thermal paper
Linux, Microsoft Windows 2000 / XP, Microsoft Windows 7, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5
Microsoft Certification
Works with Windows Vista
Enclosure Colour
Cool white
4 years warranty
14.5 cm x 19.5 cm x 14.8 cm
Printer Type
Enclosure Colour
Cool white
Printer
Print Speed
Wired
USB, serial
Character Sizes (mm)
1.41 x 3.39 mm, 0.99 x 2.4 mm
Columns
30, 40, 42, 56
Auto Cutter
Barcodes
Media Handling
Media Type
Thermal paper
Max Media Size
Roll (8 cm)
80 mm
Media Sizes
Roll (8 cm), Roll (5.8 cm)
Media Thickness Range
0.055 mm - 0.08 mm
Roll Maximum Outer Diameter
83 mm
Media Feeders
1 x manual - 1 roll - Roll (8 cm)
1 x RS-232 , 1 x USB 2.0 - 4 pin USB Type B
MTBF
360,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
UL 1950, ICES-003 Class A, FCC, CSA C22.2 No. 950
Power adapter
Environmental Standards
ENERGY STAR
Limited warranty - 4 Years
14.5 cm
19.5 cm
14.8 cm
1.6 kg
Type: Printer
Max Print Speed: [N/A]
Brand: Epson
Stock Status: Clearance
Price Range Ex VAT: 150 - 300
