Energy Star receipt printer
Bringing convenience and accuracy to fast food outlets, hospitality and retail.
- Epson TM T88IV ReStick - receipt printer - two-colour (monochrome) - thermal line
- Printer Type
- Receipt printer - thermal line - two-colour (monochrome)
- 1.8 kg
- Max Media Size
- Roll (5.8 cm)
- Max Media Size (Custom)
- 58 mm
- Print Speed
- Up to 150 mm/sec , Up to 177 mm/sec - max speed
- Max Resolution (B&W)
- 203 dpi
- Cutter
- Interface
- Serial
- Barcodes
- Code 93, Code 39, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, ITF
- Media Type
- Thermal paper, receipt paper, thermal labels
- Enclosure Colour
- Dark grey
- 14.5 cm x 19.5 cm x 14.8 cm
- Printer Type
- Enclosure Colour
- Dark grey
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- Serial
- 203 dpi
- Columns
- 35, 42, 46
- Auto Cutter
- Barcodes
Media Handling
- Media Type
- Max Media Size
- Roll (5.8 cm)
- 58 mm
- Media Sizes
- Roll (5.8 cm)
- Roll Maximum Outer Diameter
- 83 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (5.8 cm)
- Connections
- 1 x RS-232
- MTBF
- 360,000 hour(s)
- UL 1950, ICES-003 Class A, FCC, CSA C22.2 No. 950
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- 14.5 cm
- 19.5 cm
- 14.8 cm
- 1.8 kg
Epson Power Supply 100-230V | In Stock | £38.23 |
Epson UB-U05 USB Interface | In Stock | £47.93 |
Epson Ethernet Interface Card UB-E04 | In Stock | £41.84 |
