Epson TM-T20II (002A0) Built in USB + serial ,PS, Receipt printer
Quicklinx: CT9RWS00 Mfr#: C31CD52002A0
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Roll (8 cm)
More than 50 in stock
£96.66 ex VAT
£115.99 inc VAT
Affordable
This easy-to-use model is our most affordable POS receipt printer and has an 80mm printing width. Its Automatic Paper Reduction feature reduces top and bottom margins, line feed width and bar code height, allowing for flexible receipt printing. This monitors and controls the amount of paper used. Paper costs are minimised by printing the top logo of the next receipt before cutting, so the top margin is further reduced by 12mm.
Reliable
With its MTBF of 360,000 hours and a mechanism life of 15 million lines, you can rely on the TM-T20II in high-volume printing environments.
Flexible
The TM-T20II comes with a built-in USB interface and you can select from two models: 1) USB + Serial, 2) USB + Ethernet, making the model a long-term investment as it is possible to switch connectivity at any time.
Fast
Its print speeds of 200mm/sec can save you time and its competitive price and running costs can save you money, ideal for when you need to beat queues quickly.
  • POS receipt printer
    The TM-T20II is an affordable POS receipt printer with fast print speeds and economical features.
Epson TM T20II - receipt printer - monochrome - thermal line
Printer Type
Receipt printer - thermal line - monochrome
1.7 kg
United Kingdom
Max Media Size
Roll (8 cm)
Max Media Size (Custom)
80 mm
Print Speed
Up to 200 mm/sec - max speed
Max Resolution (B&W)
203 x 203 dpi
USB 2.0, serial
Media Type
Receipt paper
Enclosure Colour
Dark grey
14 cm x 19.9 cm x 14.6 cm
Printer Type
Enclosure Colour
Dark grey
United Kingdom
Printer
Print Speed
Wired
USB 2.0, serial
203 x 203 dpi
Columns
48, 64
Auto Cutter
Media Handling
Media Type
Receipt paper
Max Media Size
Roll (8 cm)
80 mm
Media Sizes
Roll (8 cm), Roll (5.8 cm)
Roll Maximum Outer Diameter
83 mm
Media Feeders
1 x manual - 1 roll - Roll (8 cm)
1 x serial , 1 x USB 2.0 - 4 pin USB Type B
Wall mount bracket, power switch cover
1 x USB cable
Media Included
Roll of media
MTBF
360,000 hour(s)
FCC Class A certified, CSA, UL, TUV, EN55022 Class A
Power supply - internal
5 °C
45 °C
10 - 90%
Sound Emission (Operating)
55 dBA
14 cm
19.9 cm
14.6 cm
1.7 kg
Type: Printer
Brand: Epson
Price Range Ex VAT: 50 - 100
