Epson TM-m30 USB Ethernet + Bluetooth With PSU + UK AC Cable - Bla
Quicklinx: CB4HWS00 Mfr#: C31CE95112A0
Built for easy connectivity with tablets
By touching an NFC-equipped mobile device or tablet to the TM-m30 printer, it is easy to pair both together to print. ePOS print , the printer's built-in intelligence that communicates with web applications, allows direct printing from ANY mobile device without the need to install or update drivers. It is available for iOS, Android and Windows .
Position anywhere thanks to its sleek, compact and stylish design
With its sleek, stylish and compact design, the new TM-m30 is ideal for tablet POS applications and fits perfectly into small and medium-sized retail and hospitality environments, helping them to operate more efficiently and productively. With Ethernet, Bluetooth or Wi-Fi interfaces, it can be integrated into virtually any operating environment. By easily swapping just two covers the printer can be placed either horizontally or vertically - therefore top load or front load is possible.
High quality and adaptable
The new DM-D30 optional display is developed to match the modern design of the TM-m30 printer and an optional tablet stand is also available. Available in both black and white, this printer can print receipts in multiple greyscales, with advanced graphic and barcode printing capabilities that allow for highly customised layouts of receipts, including logos and promotional messages, that can be added with ease.
  • Gateway to tablet POS
    Print receipts anywhere on the shop floor thanks to this printer's easy connectivity with any smart device and its compact and flexible design.
Epson TM m30 - receipt printer - B/W - thermal line
Printer Type
Receipt printer - thermal line - B/W
Max Media Size
Roll (7.95 cm)
Min Media Size (Custom)
58 mm
Max Media Size (Custom)
80 mm
Print Speed
Up to 200 mm/sec - max speed
Max Resolution (B&W)
203 x 203 dpi
Cutter
USB 2.0, LAN, Bluetooth, NFC
Media Type
Thermal paper
PNE sensor
Print server
Microsoft Certification
Compatible with Windows 7
Enclosure Colour
12.7 cm x 12.7 cm x 12.7 cm
Printer Type
Receipt printer - thermal line - monochrome
Enclosure Colour
Printer
Print Speed
Wired
203 x 203 dpi
Columns
48, 57
PNE sensor
Cutter
Media Handling
Media Type
Thermal paper
Max Media Size
Roll (7.95 cm)
58 mm
80 mm
Media Sizes
Roll (7.95 cm), Roll (5.75 cm)
Roll Maximum Outer Diameter
83 mm
Media Feeders
1 x manual - 1 roll - Roll (7.95 cm)
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Paper roll spacer, power switch cover
Media Included
1 thermal roll paper
MTBF
360,000 hours
Power adapter - external
5 °C
45 °C
10 - 90%
Sound Emission (Operating)
55 dBA
12.7 cm
12.7 cm
12.7 cm
