Use less paper
Shrink paper usage by up to 31 percent with the TM-H6000IV's paper save feature. Instead of squeezing logos and text, which causes distortion and can compromise legibility, the 'paper save' feature automatically reduces blank spaces and barcode height. It also prints the top of the next receipt before cutting the current one to decrease the top margin.
Use less power
Lower utility overheads with ENERGY STAR-qualified power efficiency.
Save time and hassle
Easily manage a fleet of TM-H6000IV printers over a network using the new remote management feature. Monitor every printer's status and usage from a single location, and carry out settings changes remotely.
Simple integration
Get the freedom to switch to a USB environment at any time, with USB included as standard in addition to the changeable second interface.
Eye-catching greyscale graphics
Make a good impression on customers with high-quality receipts. The TM-H6000IV delivers eye-catching greyscale logos and graphics, ideal for reinforcing branding or communicating special offers more effectively.
Speedy transactions
Every transaction is fast and fuss-free with the TM-H6000IV's improved print speeds of up to 300mm/sec for receipts and 5.7 lines per second for slips. To ensure customers are not frustrated by cheque processing failures, the optional MICR reader has an accuracy rate of over 99 percent.
Easy to use
Even inexperienced operators will find the TM-H6000IV easy to use - its large paper slot allows trouble-free insertion of slips and cheques. Changing consumables is a safe, one-handed job, with no sharp edges or exposed parts.
- Epson TM H6000IV - receipt printer - B/W - thermal line / dot-matrix
- Printer Type
- Receipt printer - thermal line / dot-matrix - 9 pin - B/W
- 4.4 kg
- Localisation
- Europe
- Max Media Size
- 230 x 297 mm, Roll (7.95 cm)
- Print Speed
- Up to 300 mm/sec , Up to 5.7 lines/sec
- Interface
- USB, serial
- Media Type
- Plain paper, thermal paper, receipt paper, carbon paper
- Enclosure Colour
- Dark grey
- 2-year warranty
- 18.6 cm x 27.8 cm x 18.2 cm
- Printer Type
- Receipt printer - thermal line / dot-matrix - 9 pin - monochrome
- Enclosure Colour
- Dark grey
- Localisation
- Europe
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, serial
- Character Sizes (mm)
- 1.24 x 3.1 mm, 1.56 x 3.1 mm, 1.41 x 3.39 mm, 0.99 x 2.4 mm
- Columns
- 42, 45, 56, 60
- Repeating Printing
- 3 copies
Media Handling
- Media Type
- Max Media Size
- Media Sizes
- 230 x 297 mm, Roll (7.95 cm), 68 x 152 mm
- Roll Maximum Outer Diameter
- 83 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (7.95 cm) , 1 x manual - 1 sheet - 230 x 297 mm
- Connections
- 1 x USB , 1 x RS-232 - 9 pin D-Sub (DB-9)
- Consumables Included
- 1 x ribbon (black) - Epson ERC-32
- Media Included
- 1 thermal roll paper (83mm)
- FCC Class A certified, CSA, UL, TUV, EN 60950, VCCI Class A ITE, IEC 60950, CISPR 22, GOST-R
- Power Device
- Power adapter - external
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years - carry-in
- 5 °C
- 45 °C
- 18.6 cm
- 27.8 cm
- 18.2 cm
- 4.4 kg
- Width (Shipping)
- 30 cm
- Depth (Shipping)
- 40 cm
- Height (Shipping)
- 30 cm
- Weight (Shipping)
- 5.8 kg
