Print your own labels
With the ColorWorks C3500 (TM-C3500), you can easily customise and print your own colour labels. Whether it's printing packaging labels with colourful logos and pictures or tickets and ID cards with important barcodes and product information, this printer ensures you can print it all from one machine. It also helps you conform with GHS international chemical labelling guidelines, as labels can be printed on-demand without using pre-printed templates.
High-quality and durable
Thanks to the individual pigment ink cartridges, you can create fast-drying, highly detailed labels that are smudge, water and fade resistant. Not only will your labels look great, but the pigment ink's long-lasting, durable qualities make it perfect for a wide variety of environments.
Easy-to-use 4-colour label printer
You can easily print on a wide selection of materials, including matte and glossy coated paper and filmic labels. This means you can create exactly the type of labels you need. The LCD screen displays ink levels and printer status information, while front operation and easy setup software means you can operate the printer without specialist training.
Saving you money
Thanks to individual pigment ink cartridges, this label printer is ideal for cutting printing costs with its low cost-per-label, as you only need to replace the colour used.
Colour label printer
The high-speed, high-quality colour label printer, designed to print a wide variety of labels in-house with a low cost-per-label.
- Epson TM C3500 - label printer - colour - ink-jet
- Printer Type
- Label printer - ink-jet - colour
- 12 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Max Media Size
- Continuous paper 30 mm - 112 mm (width)
- Min Media Size (Custom)
- 30 mm
- Max Media Size (Custom)
- 112 mm
- Print Speed
- Up to 103 mm/sec
- Max Resolution (B&W)
- 720 x 360 dpi
- Cutter
- Interface
- LAN, USB host
- Media Type
- Labels, continuous paper labels, die cut labels
- Black Mark sensor
- Networking
- Print server
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 31 cm x 28.3 cm x 26.1 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 4 x 360 nozzles (black, cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Type
- Epson DURABrite Ultra inks
- Print Speed
- Up to 103 mm/sec - 360x360 dpi
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- LAN, USB host
- 720 x 360 dpi
- Black Mark sensor
- Auto Cutter
Media Handling
- Media Type
- Max Media Size
- 30 mm
- 112 mm
- Max Printing Width
- 104 mm
- Roll Maximum Outer Diameter
- 101.6 mm
- Networking
- Print server
- Connections
- 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (yellow) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink maintenance kit
- Media Included
- Roll of media
- MTBF
- 88,000 hour(s)
- Power Device
- Power adapter - external
- Frequency Required
- 50 - 60 Hz
- 30 Watt
- Power Consumption Stand by
- 3 Watt
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year - carry-in
- 10 °C
- 35 °C
- 20 - 80%
- 31 cm
- 28.3 cm
- 26.1 cm
- 12 kg
- Width (Shipping)
- 44 cm
- Depth (Shipping)
- 40 cm
- Height (Shipping)
- 42.5 cm
- Weight (Shipping)
- 15.04 kg
Epson SJIC22P(C): Cyan Ink cartridge for ColorWorks C3500 | In Stock | £19.26 |
Epson SJIC22P(K): Black Ink cartridge for ColorWorks C3500 | In Stock | £19.26 |
Epson SJIC22P(M): Magenta Ink cartridge for ColorWorks C3500 | In Stock | £19.27 |
Epson SJIC22P(Y): Yellow Ink cartridge for ColorWorks C3500 | In Stock | £19.27 |
Epson Maintenance box for ColorWorks C3500 series | In Stock | £27.51 |
Epson High Gloss Label - Continuous Roll: 102mm x 33m | In Stock | £17.37 |
Epson High Gloss Label - Continuous Roll: 76mm x 33m | In Stock | £13.02 |
Epson Premium Matte Label - Continuous Roll: 76mm x 35m | In Stock | £5.74 |
Epson Premium Matte Label - Continuous Roll 105mm x 35m | In Stock | £7.50 |
Epson Premium Matte Label - Continuous Roll 76x51mm | In Stock | £5.74 |
