Designed to fit seamlessly into the office environment, the SC-T7000 features sleek styling, a small footprint, and is operated from the front to allow convenient placement against a wall.
Efficient and economical
The SC-T7000 takes just 28 seconds to produce an A1 print in draft mode on plain paper, and offers optimised running costs with a choice of 700ml, 350ml and 110ml ink cartridge sizes.
Easy to set-up and use
Straightforward to install, it integrates into most production environments. This printer is also so easy to use that operators do not need special training. All controls are at the front. Media is fed in at the top, and the finished prints emerge at the front, stacking neatly into a basket. Tracking how much paper is left on a roll is simple thanks to media barcode printing.
Durable, high-quality results
Epson UltraChrome XD Ink has been specifically developed to produce high-quality, durable prints with deep blacks, a wide colour gamut and crisp, dense lines with a minimum width of 0.02mm. This pigment-based ink is smudge, crease and water resistent, so you can also create prints for short-term outdoor use.
Reduced bills and environmental impact
Helping to reduce impact on the environment, the SC-T7000 uses water-based inks and is qualified by ENERGY STAR for its excellent power efficiency.
This product is now compatible with AllPlan Engineering, CAD software that supports the whole architectural design process, providing a complete solution for the CAD market.
The SC-T7000 takes just 28 seconds to produce an A1 print in draft mode on plain paper, and offers optimised running costs with a choice of 700ml, 350ml and 110ml ink cartridge sizes. -
Straightforward to install, it integrates into most production environments. This printer is also so easy to use that operators do not need special training. All controls are at the front. Media is fed in at the top, and the finished prints emerge at the front, stacking neatly into a basket. Tracking how much paper is left on a roll is simple thanks to media barcode printing. -
Epson UltraChrome XD Ink has been specifically developed to produce high-quality, durable prints with deep blacks, a wide colour gamut and crisp, dense lines with a minimum width of 0.02mm. This pigment-based ink is smudge, crease and water resistent, so you can also create prints for short-term outdoor use. -
- Epson SureColor SC-T7000 - large-format printer - colour - ink-jet
- Printer Type
- 44" large-format printer - ink-jet - colour
- 82 kg
- Inkjet Technology
- Epson Micro Piezo TFP
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, photo black or matte black
- Max Media Size
- Roll (111.8 cm)
- Max Media Size (Custom)
- 1118 mm
- Max Resolution (B&W)
- 2880 x 1440 dpi
- Max Resolution (Colour)
- 2880 x 1440 dpi
- Interface
- USB, Gigabit LAN
- Language Simulation
- HP RTL, EPSON ESC/P, HP GL/2
- Media Type
- Plain paper, thick paper
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 160.8 cm x 81.3 cm x 112.8 cm
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 720 nozzles (black), 720 nozzles (per colour)
- Minimum Ink Droplet Size
- 3.5 pl
- Ink Cartridge Configuration
- 5 individual ink tanks
- Ink Type
- Epson UltraChrome XD Ink
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 2880 x 1440 dpi
- 2880 x 1440 dpi
Media Handling
- Media Type
- Max Media Size
- Roll (111.8 cm)
- 1118 mm
- Media Sizes
- A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), B4 (250 x 353 mm), B3 (353 x 500 mm), B2 (500 x 707 mm), B1 (707 x 1000 mm), A3 plus (329 x 423 mm), Roll (111.8 cm), Roll (43.2 cm), Roll (61 cm)
- Media Thickness Range
- 0.08 mm - 1.5 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (111.8 cm)
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Included Accessories
- Stand
- Consumables Included
- 1 x ink cartridge (matte black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black)
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 72 Watt
- Power Consumption Stand by / Sleep
- 0.4 Watt
- Software Included
- Drivers & Utilities, EpsonNet Print, EpsonNet Config
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- Sound Emission (Operating)
- 50 dBA
- 160.8 cm
- 81.3 cm
- 112.8 cm
- 82 kg
