Epson SureColor SC-T3200 Colour Inkjet Printer
Quicklinx: 9RYJWS00 Mfr#: c11cd66301a0
  • Windows 8 (32/64 bits)
Ideal for graphics, CAD and GIS
The SureColor SC-T3200 is one of the SureColor SC-T series of high-speed, four-color large-format printers, designed to produce a wide range of high-quality graphics, CAD and GIS applications in design, commercial print, copy shop, architecture, building, engineering, retail and education environments.
Highly productive
To maximise productivity, the SureColor SC-T3200 features 1GB of RAM for ultra-fast image processing, and an optional 320GB HDD for job caching and recall. Optional PostScript support with dual 1.6GHz CPUs enables printing of large data-rich files quickly and directly from leading design and CAD programs. And the SureColor SC-T3200 is fast — outputting an A1 print takes just 28 seconds.
High quality output
The combination of Epson’s PrecisionCore TFP printheads and UltraChrome XD pigment ink delivers industry-leading output quality and precise, repeatable performance. UltraChrome XD pigment ink is smudge and water resistant and delivers deep blacks and crisp, dense lines — ideal for technical graphics — and the vibrant colors necessary for high-quality prints and posters, on coated and non-coated media — including board up to 1.5mm thick.
Compact, quiet and easy to use}
With its sleek styling, compact footprint, low noise levels and front operation, the SureColor SC-T3200 is designed to fit easily into an office environment.
  • Ideal for graphics, CAD and GIS
    The SureColor SC-T3200 is one of the SureColor SC-T series of high-speed, four-colour large-format printers, designed to produce a wide range of high-quality graphics, CAD and GIS applications in design, commercial print, copy shop, architecture, building, engineering, retail and education environments.
  • High quality output
    The combination of Epson's PrecisionCore TFP printheads and UltraChrome XD pigment ink delivers industry-leading output quality and precise, repeatable performance. UltraChrome XD pigment ink is smudge and water resistant and delivers deep blacks and crisp, dense lines - ideal for technical graphics - and the vibrant colours necessary for high-quality prints and posters, on coated and non-coated media - including board up to 1.5mm thick.
  • Compact, quiet and easy to use
Epson SureColor SC-T3200 - large-format printer - colour - ink-jet
Printer Type
24" large-format printer - ink-jet - colour
67 kg
Inkjet Technology
Epson PrecisionCore
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, photo black or matte black
Max Media Size
Roll A1 (61.0 cm)
Max Media Size (Custom)
610 mm
Print Speed
Up to 2.14 ppm - colour - A1 (594 x 841 mm) , Up to 2.14 ppm - B/W - A1 (594 x 841 mm)
Max Resolution (B&W)
2880 x 1440 dpi
Max Resolution (Colour)
2880 x 1440 dpi
Cutter
USB, Gigabit LAN
RAM Installed (Max)
1 GB
Language Simulation
HP RTL, HP GL/2, EPSON ESC/P Raster
Media Type
Plain paper
Print server
Linux, Microsoft Windows XP, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Apple MacOS X 10.5.8 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition
Microsoft Certification
Compatible with Windows 7
105 cm x 81.3 cm x 111.7 cm
Printer Type
Printer
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
720 nozzles (black), 720 nozzles (per colour)
Minimum Ink Droplet Size
3.5 pl
Ink Cartridge Configuration
5 individual ink tanks
Ink Type
Epson UltraChrome XD Ink
Print Speed
Built-in Devices
Status LCD
Wired
USB, Gigabit LAN
2880 x 1440 dpi
2880 x 1440 dpi
PostScript Support
Optional
Language Simulation
Cutter
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Plain paper
Max Media Size
Roll A1 (61.0 cm)
610 mm
Media Sizes
A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), B4 (250 x 353 mm), B3 (353 x 500 mm), B2 (500 x 707 mm), B1 (707 x 1000 mm), Roll (43.2 cm), Roll (61 cm)
Media Thickness Range
0.08 mm - 1.5 mm
Media Feeders
1 x manual - 1 roll - Roll A1 (61.0 cm)
Print server
1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
Stand
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black)
Power supply - internal
Frequency Required
50/60 Hz
52 Watt
Power Consumption Stand by
3 Watt
Software Included
Drivers & Utilities
105 cm
81.3 cm
111.7 cm
67 kg
9RYJ Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.99
9RYJ Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.99
9RYJ Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £15.50
9RYJ Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £21.07
9RYJ Epson A3 Matte Paper Heavyweight 50 sheets In Stock £28.72
