Superior quality prints
Using UltraChrome HD ink, our new nine-colour ink-set, the SC-P800 produces true-to-life photos with vivid colours and the deepest blacks on the market . Your prints will last for ages thanks to the inks' improved lightfastness , and large 80ml ink cartridges mean fewer trips to change the ink.
Print on a range of media
The SC-P800 is the smallest A2 printer with roll paper option , which enables users to print panoramic photos on formats such as banners and gallery wrap canvas. Three paper paths, including a front-loading fine art paper path, means users can easily switch between different formats.
Stay connected
With the SC-P800, it is easier than ever before to print from a whole range of devices. This model is the first 17-inch photo printer with wireless functionality and Epson Connect compatibility for great flexibility and freedom, meaning easy printing from tablets, PCs and smartphones. Wi-Fi Direct is also supported, meaning the printer can easily communicate with your smart devices.
Easy-to-use
The SC-P800 features quick, simple set-up and operation thanks to a large 2.7-inch colour touch panel. It guides the user through how to load different media types and enables them to easily switch between these before printing.
High-quality look and feel
A new sleek, modern design means the printer has the smallest footprint of any A2 printer on the market and it fits well where space is an issue, at home or in the studio.
A2 desktop photo printer
Superior-quality A2 photo printer with flexible connectivity and roll paper option for creating professional prints on a range of media.
- Epson SureColor SC-P800 - large-format printer - colour - ink-jet
- Printer Type
- 17" large-format printer - ink-jet - colour
- 19.5 kg
- Inkjet Technology
- Epson On-demand Inkjet
- Ink Palette Supported (Colours)
- 8-ink - cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, photo black or matte black
- Max Media Size
- Roll (43.2 cm)
- Max Media Size (Custom)
- 432 mm
- Print Speed
- Up to 3 ppm - B/W (ISO/IEC 24734) , Up to 3 ppm - colour (ISO/IEC 24734)
- Max Resolution (B&W)
- 2880 x 1440 dpi
- Max Resolution (Colour)
- 2880 x 1440 dpi
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Preview Screen Size
- 2.7"
- Media Type
- Envelopes, plain paper, photo paper, glossy photo paper, CD/DVD labels, glossy paper
- Total Media Capacity
- 120 sheets
- Media Handling
- 120-sheet input tray, CD/DVD tray, 1-sheet manual tray
- Networking
- Print server
- Power
- AC 230V
- System Requirements
- Microsoft Windows XP 64-bit Edition, Microsoft Windows XP SP1 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.6.8 or later, Windows 8 (32/64 bits), Android 4.0 or later, Windows 8.1 (32/64 bits), Apple iOS 7
- 1-year warranty
- 68.4 cm x 37.6 cm x 25 cm
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 180 nozzles (black), 180 nozzles (per colour)
- Minimum Ink Droplet Size
- 3.5 pl
- Ink Cartridge Configuration
- 8 individual ink tanks
- Ink Type
- Epson UltraChrome HD Ink
- Print Speed
- Built-in Devices
- Touch screen
- 2.7"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 2880 x 1440 dpi
- 2880 x 1440 dpi
- Media Handling
Media Handling
- Media Type
- Max Media Size
- Roll (43.2 cm)
- 432 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), B4 (250 x 353 mm), B3 (353 x 500 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, Roll (43.2 cm), B6 (125 x 176 mm), 200 x 250 mm, 130 x 200 mm, A3 Plus (329 x 483 mm)
- Envelope Sizes
- International C6 (114 x 162 mm), International C5 (162 x 229 mm), International C4 (229 x 324 mm)
- Media Thickness Range
- 0.29 mm - 1.5 mm
- Media Weight
- 73 g/m² - 1000 g/m²
- 120 sheets
- Media Feeders
- 1 x manual - 1 roll - Roll (43.2 cm) , 1 x automatic - 120 sheets
- Networking
- Print server
- WEP, WPA-PSK, WPA2, Wi-Fi Direct
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (cyan) , 1 x ink cartridge (vivid magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x ink cartridge (light black) , 1 x ink cartridge (light light black) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (vivid light magenta)
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50 - 60 Hz
- 21 Watt
- Power Consumption Sleep
- 1.8 Watt
- OS Required
- Limited warranty - 1 year - on-site
- 68.4 cm
- 37.6 cm
- 25 cm
- 19.5 kg
Ink (7)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £12.88 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £9.92 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £9.92 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £12.41 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £12.00 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £19.38 |
Epson A3 Matte Paper Heavyweight 50 sheets | In Stock | £24.79 |
Other bundles (2)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.10 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.60 |
