High quality
Create glossy photos with a wide range of vivid colours thanks to a seven-colour UltraChrome HiGloss 2 ink-set with gloss optimiser. Creating the smallest ink droplet size of any A3+ photo printer on the market , the SC-P400 delivers superb accuracy and overall quality.
Flexible and versatile
Designed to give photographers the choice to display their prints on different media, the SC-P400 supports fine art, glossy and matte papers, up to A3+ in size and up to 1.3mm thick. The ability to load paper from the rear allows you to print onto fine art paper easily, while printing on 2-inch core roll media allows to print panoramics and individual formats. CD and DVD printing is also supported.
Advanced connectivity
Designed for maximum connectivity, the printer features built-in Ethernet and USB capability as well as Wi-Fi for wireless printing from PCs, tablets and smartphones, supported by the free Epson iPrint App .
Compact and stylish
This stylish desktop printer complements any home, studio or office environment. It is also the smallest and lightest A3+ photo printer using pigment inks on the market so it won't take up too much precious desk or counter space.
Reduces environmental impacts
In addition, the SC-P400 has a very low power consumption and is consequently EnergyStar 2.0 compliant.
Professional desktop photo printer
Perfect for photography enthusiasts wanting to create professional-quality photos using pigment inks, the versatile and stylish SC-P400 supports a range of media in sizes up to A3+. -
Print professional-quality photos up to A3+
The SureColor SC-P400 offers photo enthusiasts a highly versatile photo printer, which combines pigment inks and comprehensive connectivity in one affordable package.Perfect for use in the home, studio or office, every aspect of this compact and stylish printer has been considered to deliver the ultimate in quality and flexibility to photographers who wish to print stunning images quickly and easily.Combining Epson's UltraChrome HiGloss 2 pigment inks with flexible mobile printing and connectivity, means users can produce professional-quality results on different media. -
Vibrant and long-lasting colour
Our dedicated UltraChrome HiGloss 2 pigment ink-set is a seven colour system plus an enhanced gloss optimiser which produces unparalleled glossy prints with greater vibrancy, crisp colours, rich blacks and accurate skin tones. As well as producing professional-quality results, the ink-set is the most affordable pigment ink-set on the market to help users reduce their printing costs. -
Superb detail
Capture every last detail with Epson's highly reliable Micro-Piezo printheads. Delivering the smallest ink droplet size of any A3+ photo printer on the market , users can be confident their photo prints will be incredibly accurate and will look great. -
Wide choice of print media
Designed to give photographers the freedom to display their prints in a number of ways, the SC-P400 supports a number of sheet and roll media formats in sizes up to A3+. For those wanting to produce prints fit for a gallery, the printer features an easy-to-use, rear-loading fine art paper path. This allows users to print onto thicker media, up to 1.3mm, for rigid photos which are easy to display. For larger prints, panoramics or special formats, roll media is supported. -
Designed for maximum connectivity, this printer gives you more flexibility than ever before. Built-in Ethernet means it can be easily connected to the network in a home or studio. Wireless printing is easy thanks to Wi-Fi connectivity and users can simply download the Epson iPrint App to print photos wirelessly from a range of mobile devices, including phones and tablets, from almost anywhere and at any time . -
Compact and stylish
Incredibly small and light, the SC-P400 helps save precious desk and counter space, plus its stylish and professional design makes it the ideal addition to any modern home, studio and office. -
- Epson SureColor SC-P400 - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- 12.3 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 7-ink - cyan, magenta, yellow, photo black or matte black, red, orange, gloss optimizer
- Media Size Class
- A3
- Max Media Size
- A3 Plus (329 x 483 mm)
- Print Speed
- Up to 9 ppm - B/W , Up to 5 ppm - colour
- Max Resolution (B&W)
- 5760 x 1440 dpi
- Max Resolution (Colour)
- 5760 x 1440 dpi
- Interface
- USB 2.0, LAN, Wi-Fi
- Media Type
- Plain paper, CD/DVD labels, thick paper, postcards
- Total Media Capacity
- 120 sheets
- Media Handling
- 120-sheet input tray, CD/DVD tray
- Networking
- Print server
- System Requirements
- Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- 62.2 cm x 32.4 cm x 21.9 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (black), 180 nozzles (per colour)
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Cartridge Configuration
- 8 individual ink tanks
- Ink Type
- Epson UltraChrome Hi-Gloss2
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 5760 x 1440 dpi
- 5760 x 1440 dpi
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm, A3 Plus (329 x 483 mm)
- Media Thickness Range
- 0.08 mm - 1.3 mm
- 120 sheets
- Media Feeders
- 1 x automatic - 120 sheets - A3 Plus (329 x 483 mm)
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x ink cartridge (gloss optimiser) , 1 x ink cartridge (orange) , 1 x ink cartridge (red) , 1 x ink cartridge (yellow) , 1 x ink cartridge (magenta) , 1 x ink cartridge (cyan)
- ISO 7779
- Power Device
- Power supply - internal
- Frequency Required
- 50 - 60 Hz
- 20 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Sound Emission (Operating)
- 52.8 dBA
- 62.2 cm
- 32.4 cm
- 21.9 cm
- 12.3 kg
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.99 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £14.09 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £21.42 |
Epson A3 Matte Paper Heavyweight 50 sheets | In Stock | £29.33 |
