Epson SureColor SC-P400 A3+ Colour Inkjet Printer with WiFi
Quicklinx: BR93WS00 Mfr#: C11CE85301
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
High quality
Create glossy photos with a wide range of vivid colours thanks to a seven-colour UltraChrome HiGloss 2 ink-set with gloss optimiser. Creating the smallest ink droplet size of any A3+ photo printer on the market , the SC-P400 delivers superb accuracy and overall quality.
Flexible and versatile
Designed to give photographers the choice to display their prints on different media, the SC-P400 supports fine art, glossy and matte papers, up to A3+ in size and up to 1.3mm thick. The ability to load paper from the rear allows you to print onto fine art paper easily, while printing on 2-inch core roll media allows to print panoramics and individual formats. CD and DVD printing is also supported.
Advanced connectivity
Designed for maximum connectivity, the printer features built-in Ethernet and USB capability as well as Wi-Fi for wireless printing from PCs, tablets and smartphones, supported by the free Epson iPrint App .
Compact and stylish
This stylish desktop printer complements any home, studio or office environment. It is also the smallest and lightest A3+ photo printer using pigment inks on the market so it won't take up too much precious desk or counter space.
Reduces environmental impacts
In addition, the SC-P400 has a very low power consumption and is consequently EnergyStar 2.0 compliant.
  • Professional desktop photo printer
    Perfect for photography enthusiasts wanting to create professional-quality photos using pigment inks, the versatile and stylish SC-P400 supports a range of media in sizes up to A3+.
  • Print professional-quality photos up to A3+
    The SureColor SC-P400 offers photo enthusiasts a highly versatile photo printer, which combines pigment inks and comprehensive connectivity in one affordable package.Perfect for use in the home, studio or office, every aspect of this compact and stylish printer has been considered to deliver the ultimate in quality and flexibility to photographers who wish to print stunning images quickly and easily.Combining Epson's UltraChrome HiGloss 2 pigment inks with flexible mobile printing and connectivity, means users can produce professional-quality results on different media.
  • Vibrant and long-lasting colour
    Our dedicated UltraChrome HiGloss 2 pigment ink-set is a seven colour system plus an enhanced gloss optimiser which produces unparalleled glossy prints with greater vibrancy, crisp colours, rich blacks and accurate skin tones. As well as producing professional-quality results, the ink-set is the most affordable pigment ink-set on the market to help users reduce their printing costs.
  • Superb detail
    Capture every last detail with Epson's highly reliable Micro-Piezo printheads. Delivering the smallest ink droplet size of any A3+ photo printer on the market , users can be confident their photo prints will be incredibly accurate and will look great.
  • Wide choice of print media
    Designed to give photographers the freedom to display their prints in a number of ways, the SC-P400 supports a number of sheet and roll media formats in sizes up to A3+. For those wanting to produce prints fit for a gallery, the printer features an easy-to-use, rear-loading fine art paper path. This allows users to print onto thicker media, up to 1.3mm, for rigid photos which are easy to display. For larger prints, panoramics or special formats, roll media is supported.
  • Advanced connectivity
    Designed for maximum connectivity, this printer gives you more flexibility than ever before. Built-in Ethernet means it can be easily connected to the network in a home or studio. Wireless printing is easy thanks to Wi-Fi connectivity and users can simply download the Epson iPrint App to print photos wirelessly from a range of mobile devices, including phones and tablets, from almost anywhere and at any time .
  • Compact and stylish
    Incredibly small and light, the SC-P400 helps save precious desk and counter space, plus its stylish and professional design makes it the ideal addition to any modern home, studio and office.
  • Reduces environmental impacts
Epson SureColor SC-P400 - printer - colour - ink-jet
Printer Type
Photo printer - ink-jet - colour
12.3 kg
Inkjet Technology
Epson Micro Piezo
Ink Palette Supported (Colours)
7-ink - cyan, magenta, yellow, photo black or matte black, red, orange, gloss optimizer
Media Size Class
A3
Max Media Size
A3 Plus (329 x 483 mm)
Print Speed
Up to 9 ppm - B/W , Up to 5 ppm - colour
Max Resolution (B&W)
5760 x 1440 dpi
Max Resolution (Colour)
5760 x 1440 dpi
USB 2.0, LAN, Wi-Fi
Media Type
Plain paper, CD/DVD labels, thick paper, postcards
Total Media Capacity
120 sheets
Media Handling
120-sheet input tray, CD/DVD tray
Print server
Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
62.2 cm x 32.4 cm x 21.9 cm
Printer Type
Printer
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (black), 180 nozzles (per colour)
Minimum Ink Droplet Size
1.5 pl
Ink Cartridge Configuration
8 individual ink tanks
Ink Type
Epson UltraChrome Hi-Gloss2
Print Speed
Wireless
USB 2.0, LAN, Wi-Fi
5760 x 1440 dpi
5760 x 1440 dpi
Media Handling
Media Handling
Media Type
Media Size Class
A3
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm, A3 Plus (329 x 483 mm)
Media Thickness Range
0.08 mm - 1.3 mm
120 sheets
Media Feeders
1 x automatic - 120 sheets - A3 Plus (329 x 483 mm)
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x ink cartridge (gloss optimiser) , 1 x ink cartridge (orange) , 1 x ink cartridge (red) , 1 x ink cartridge (yellow) , 1 x ink cartridge (magenta) , 1 x ink cartridge (cyan)
ISO 7779
Power supply - internal
Frequency Required
50 - 60 Hz
20 Watt
Power Consumption Sleep
0.3 Watt
Sound Emission (Operating)
52.8 dBA
62.2 cm
32.4 cm
21.9 cm
12.3 kg
BR93 Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £14.99
BR93 Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.37
BR93 Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.37
BR93 Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £14.69
BR93 Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £14.69
BR93 Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £21.42
BR93 Epson A3 Matte Paper Heavyweight 50 sheets In Stock £29.33
