Enjoy wireless access to this fast, high quality all-in-one and make printing and scanning even easier. With the large 6.3 cm LCD viewer you can also view, select and print your photos straight from your digital camera´s memory card without the need to switch on your PC.
Whether you print photos or make quick copies of documents, Epson DURABrite Ultra Ink gives you superb prints that are resistant to water, fading and even highlighter pens. And with individual inks you only need to replace the color used, which saves you money too.
- Epson Stylus SX515W - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 36 ppm (mono) / up to 36 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Scanning
- 2400 x 2400 dpi
- Display
- 2.5"
- Original Size
- 216 x 297 mm (max)
- Media Size
- 216 x 356 mm (max)
- Media Type
- Plain paper, photo paper
- Standard Media Capacity
- 120 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, USB host, Wi-Fi
- Office Machine Features
- Print from memory card, print from USB flash drive
- Power
- AC 230 V (50/60Hz)
- 45 cm x 34.2 cm x 18.2 cm
- 6.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- Display Diagonal Size
- 2.5"
- Interface
- Supported Flash Memory
- Memory Stick, CompactFlash, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick PRO, USB flash drive, SDHC Memory Card
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 2 pl
- Ink Type
- Epson DURABrite Ultra inks
Scanning
- Scan Element
- CIS
- Optical Resolution
- 2400 x 2400 dpi
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Max Media Size
- Other
- Supported Media Type
- 120 sheets
- Speed Details
- Printing: up to 36 ppm (A4) - B/W , Printing: up to 36 ppm (A4) - colour , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- WEP, WPA-PSK
- Operating System Support
- MS Windows XP, MS Windows 2000, Apple Mac OS X 10.3.9, MS Windows Vista, MS Windows XP 64-bit Edition
- Software Included
- Epson Event Manager, EPSON Web-to-Page, ABBYY FineReader 5.0 Sprint Plus, ABBYY FineReader 6.0 Sprint Plus, Epson Easy Photo Print
- Voltage Required
- Direct Printing Specifications
- PictBridge
- Included Accessories
- USB cable
- Consumables Included
- 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (black)
- ENERGY STAR Certified
- Limited warranty - 1 year
- 45 cm
- 34.2 cm
- 18.2 cm
- 6.1 kg
- Sound Emission
- 5.5 dBA (idle) / 42.5 dBA (operating)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £16.60 |
Epson T071 Black Ink Cartridge | In Stock | £17.58 |
Epson Premium Glossy A4 Photo Paper 15 Sheets | In Stock | £13.03 |
Epson Premium Glossy Photo Paper - glossy photo paper - 15 sheet(s) | In Stock | £13.08 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.96 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.99 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.44 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £15.44 |
